Engine n00b
truck died on me tonight
looking for t-shooting ideas for the morning.
350, HEI distrib. I gassed it before warmed up and had a pop and it died and wouldnt refire (and typically does fine) when I first had the engine put in, this happened once and it was a bad distrib wire.. unfortunately, im a computer guy not a mechanic, so I am not sure where to start. Im planning on packing a small toolbox and heading over in the morning... |
Re: truck died on me tonight
Pull off your distributor cap, make a note of where the distributor rotor is pointing, get in the truck and bump the starter a couple of times, then go back and see if the distributor rotor moved. I'm guessing it hasn't, which means: broken distributor gear roll pin, or broken timing chain.
Josh '70 Custom Camper / 20 |
a common hei problem is the modules get fried especially if the original ruck wiring was used// unhook the wire to dizzy and turn the key on and use volt meter to see hoif theres voltage to that wire if so how much?
Engine n00b
Also - this is a Skip White HEI, and if it IS the second time it's a bad connection at the distro wire, I think it might be time to say goodbye.
Junior Member
Had a module die more than once my self. There is no warning. It works then it doesen't.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
dazed and confused
i had this happen once. i ended up running a new to the dist. and it works fine now.
members met: redbaron69, billsbowtie,nc67 |
Engine n00b
Im electrical and starting system retarded.. I put a voltmeter on the red wire going into the HEI (that comes from the starter, right?) and "tried" to ground the other (may have been a poor ground) and got 0.00 there.
I tried to remove the cap - I got to the ignition module inside, but couldnt find how to get further than that. |
#8 | |
Kung Fu Master
![]() Join Date: Oct 2005
Was the key in the "run" position when you tried to get a voltage reading? There should only be one wire running to the dist.
Also, I had a backfire one time through the carb and it made my choke stuck shut thus making it not want to start because it was flooded. Make sure your choke is working freely. I think you can pull the module out and have it tested at most local parts stores.
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
this happened to me
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
70 Chevrolet=Obsession
FWIW, about a month ago I was driving my 70 home and it was like somebody switched off my ignition. After the engine cooled down it ran OK so I limped home. I was running a 82 Chev pickup HEI. I talked to some knowledgeable automotive friends and they said it's the module in the HEI. Bought a new MSD "Streetfire" HEI and installed it. So far everything's OK.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
#12 | |
Engine n00b
I didn't trace the cable, just went into a harness that appeared to head that away. The fusebox - so there should NOT be a fuse there then.. how silly - whats the point? |
#13 |
if you feed wire to the hei is coming from the original factory harness THAT'S A PROBLEMyou r not getting full voltage to the dizzy the low voltage will burn modules up on a regular basis due to the low voltage
#14 |
I don't see why there would be no fuse. I am thinking that you need a fuse.
__________________________________________ Sean 1972 C20 2005 4Runner ![]() |
#15 | |
Between Trucks...
Beat it to fit, Paint it to match... ![]() |
#16 | |
One day.....
DZL1. |
#17 |
no the power needs to come from a switched power source// any doubts check the FAQ section on how to properly install an hei dizzy
#18 |
what CDOWNS said.... good place to start
#19 |
two wires there if he has a tach.
Toss the old espestis wire and run a brand new one with a fuse.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
