Old 10-18-2009, 08:20 AM   #1
Mowdigger
Mowdigger's Avatar
Radiator Core support question
Can someone tell me what the differences are between a 68 and a 71 C10 core support, besides 3 years ? Thanks Scott
Mowdigger is offline   Reply With Quote
Old 10-18-2009, 10:14 AM   #2
redbaron69
redbaron69's Avatar
Re: Radiator Core support question
i know the 67-68 takes smaller bushings were the support mounts to frame.
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 10-18-2009, 10:26 AM   #3
crites_72
crites_72's Avatar
interested also. or if theres a way to make the 69-72 work for a 67-68
DJ
crites_72 is offline   Reply With Quote
Old 10-18-2009, 10:28 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Totally different in the headlight area. The 69-72 units have buckets for the headlight assembly to sit into, versus the 67-68 having no buckets.
Old 10-18-2009, 10:48 AM   #5
Mowdigger
Mowdigger's Avatar
So, that's why you have to take the buckets off your 71 and install on the 67-68 ? I'm changing my front end on my 71 to a 68 and was wondering why the 71 support wouldn't work with the 68 sheetmetal ?
Old 10-18-2009, 02:53 PM   #6
evilways
evilways's Avatar
I will add my info on this. I have a later year on mine. The only thing I can tell you is that 67-68 headlight mount is part of the core itself, the later ones have buckets and stick out a few inches more. This is why my truck is bug eyed right now. Don’t shortcut this one unless you don’t care about the looks, I can’t even put on the headlight bezel on because the screwed on headlight buckets stick out too far and are not strait. So I got one light pointing down and the other is kind of strait.
Mark
1967 C/10 stepside lwb daily driver
1968 C/10 fleetside lwb parts truck
1971 Cheyenne Super swb project
evilways is offline   Reply With Quote
Old 10-18-2009, 02:56 PM   #7
evilways
evilways's Avatar
This only applies if you’re going to 67-68 grills from later years. I my experience it don’t work very well.
Mark
Old 10-18-2009, 03:02 PM   #8
Tx Firefighter
Plus the 67-68 ones have a row of weldnuts across the bottom for the lower grille splash panel to bolt into.
Old 10-18-2009, 05:31 PM   #9
Mowdigger
Mowdigger's Avatar
Thanks guys, mine has the nuts on the front which is different from my 71, so now I'm sure I have the correct one. Now , are the hood hinges the same on the two or are they different?
Old 10-18-2009, 08:34 PM   #10
redbaron69
redbaron69's Avatar
i could be wrong, but the hood hendges should be the same for all years. good luck
Old 10-19-2009, 01:44 AM   #11
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
The hood latches are different also.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
