Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-18-2009, 11:21 AM   #1
merlinman572
merlin572 keeps poppin dipstick out
hi i have a merlin 572 in my twin cab c30 1977 pickup i use this on street and strip its running 13.008 @103mph quarter mile and still all steel problem i have is now and again dipstick blows out but compression tested and all seems good and cant feel any pressure by putting finger over end any suggestions most welcome merlinman 572 from the uk pics can be seen on youtube under merlinman572 cheers
merlinman572 is offline   Reply With Quote
Old 10-18-2009, 11:55 AM   #2
77nomad
77nomad's Avatar
Location: Muskegon, MI (the beer tent capitol of the world)
Re: merlin572 keeps poppin dipstick out
I seen a pic of an old '69 Camaro Trans Am Racer in Chevy Hi Performance where the guy drilled maybe an .080" hole in the end of a stock dipstick and then another in the bracket that mounts the tube itself. He then ran a spring beween the two. Simular to a throttle return spring. Another thing you cold do is run a crankcase evac system like the ones from moroso. Basicly a breather in the valve cover with a tube that runs down to a bung in the header collecter. I'm not sure the can be run with mufflers or not. Anyway I'll look for that pic.
77nomad is offline   Reply With Quote
Old 10-18-2009, 01:59 PM   #3
77nomad
77nomad's Avatar
My scanner is down this is the best I could do.
Old 10-18-2009, 02:14 PM   #4
merlinman572
thanks for the tip thought about installing a t section into dipstick housing then hose upto oil catch tank
Old 10-19-2009, 09:45 PM   #5
james colbert
Do you have a good valve crank case vent? There is pressure comming from somewhere
james colbert is offline   Reply With Quote
Old 10-20-2009, 01:44 AM   #6
Rodms
Rodms's Avatar
How much vacum? and the crank case pressure could need a evac system to pull some and releive pressure
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 10-20-2009, 08:42 PM   #7
Marv D
Registered Truck Offender
Marv D's Avatar
DITTO!!! find why you have so much blowby and cure the problem, not the symptom.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 04-17-2010, 04:13 PM   #8
EVBuilder
EVBuilder's Avatar
Early 1980's Ford AIR pump connected to valve cover is a cheap alternative to the expensive aftermarket vacuum pumps. Drawing a vacuum in the crankcase is worth a few extra horse power as well as saving gaskets and seals.
EVBuilder is offline   Reply With Quote
Old 04-17-2010, 04:24 PM   #9
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
I can tell you if you are trying to run breathers in place of a PVC.....aint gunna work. I was told it would and now I have to pull the top of my tunnel ram off so I can drill/tap it to run a PVC line. If you think about it, besides a breather, there is really not anywhere else for that pressure to go. Clamp down that dipstick and something else is going to go. Seals won't win that battle.
prostreetC-10 is offline   Reply With Quote
Old 04-17-2010, 04:45 PM   #10
cableguy0
Its needs a pcv. breathers arent meant to let air out. They are meant to filter incoming air to replace the air sucked out by the pcv
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-17-2010, 05:18 PM   #11
77nomad
77nomad's Avatar
Or maybe its the flux capacitior. That thread is a year and a half old.
Old 04-17-2010, 05:47 PM   #12
regan wilson
regan wilson's Avatar
The problem doesnt have be blowby . Crankcase windage can cuase it too . The last time I had a dipstick and had that problem I just put a vacuum cap with a hoseclamp on the tube and took it off when I wanted to check the oil.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 04-18-2010, 08:56 PM   #13
nxtruck
nxtruck's Avatar
Exactly. Windage can and will cause this to happen. I cured this problem on my 434 by plumbing a Moroso evac. system to the headers. Before I ran the evac, I had a small leak at the rear of the pan. But, after I hooked the evac. system up, no more leaks.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 04-19-2010, 07:09 AM   #14
regan wilson
The only problem with that type of evac system is if you run mufflers you can end up with them full of oil . Ive seen some dripping oil before and of course smoking .
Old 04-19-2010, 11:25 PM   #15
nxtruck
nxtruck's Avatar
Yeah, I've seen that, too. My setup will pull right around 5" or so at 7000 or so. Just cruising around it barely pulls 1", but 1" is better than no vacuum and open breathers. I haven't had problems with oily mufflers.
Chris
