Old 10-18-2009, 04:20 PM   #1
70k52wd
Blaze-Air
70k52wd's Avatar
71 c-10 w/cab marker lights
I'm going to go look at this 71 I found on CL. It says right on the spid, "marker lamps". I know you could special order all kinds of combinations back in the day. This I would think is a strange option for a c-10. Would this be a c-20 or c-30 cab that was moved to the c-10 line? Are the cab mounts the same for the c-10, 20, 30? For some reason I was thinking they were different mounts. What do you all think? any opinions on this trucks options? It also has a spotlight, and had dealer a/c. The a/c is gone, but owner has the paperwork stating a/c was on it. Just thought it might be a pretty cool truck to use for a daily.
http://washingtondc.craigslist.org/m...425429578.html
70k52wd is offline   Reply With Quote
Old 10-18-2009, 04:35 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 71 c-10 w/cab marker lights
the spid has the VIN which says it's a half ton truck.
It was never a common option for a half ton truck, but it was in fact an option... as seen on that SPID
Old 10-18-2009, 04:46 PM   #3
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Adding the marker lamps to the mirrors and heavy rear spring, the original owner probably planned on towing something, or had a camper in the bed.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 10-18-2009, 04:51 PM   #4
70k52wd
Blaze-Air
70k52wd's Avatar
Thanks LM, I was hoping you would chime in.
I was reading a thread just this morning about a sweet 68 gold/white custom camper. There were some cab mounts comments about the difference between c10-20, 30 mounts being different. Not ever owning a 20-30 I didn't even know there were different cab mounts.
Question is: would this have in fact been a 20-30 cab that was moved to the 10 line. And if that is the case, were the 20-30 mounts used for this truck. Just curious about the way it would have come down the line for assembly. Thanks.
Old 10-18-2009, 06:58 PM   #5
19723DR
19723DR's Avatar
My 71 1/2 ton Cheyenne had a similar spid. 402 BB, heavy rear springs, marker lights, auxillary gas tanks. I imagine these trucks were built for towing. I'm pretty sure the cab on that truck is the factory and not swapped.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 10-18-2009, 07:26 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
I also have 2, 1/2 ton 4x4s that both have them. A 70 and 71
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-18-2009, 11:43 PM   #7
Longhorn Man
the cabs are the same, the mount defferences in the cab mounts are due to the frame.
Not all one tons had the marker/ID lights on top... mine is one of them. They were only required when dual rear wheels were ordered.
Since the cabs are the same, and all the trucks came down the same assembly line, the cab was not pulled from a one ton for this truck.
