Old 10-18-2009, 04:29 PM   #1
silver7
silver7's Avatar
Help - 12 bolt rear swap for 71 C10 4X4
I had my 12 bolt powdercoated after chem stripping but the pitting from the rust caused it to look terrible. As a result I am in the market for a replacement.
My question to the forum is what kind of problem would I run into if I swapped my 12 bolt for a 85 silverado 4X4 12 bolt? Anyone know if the dimensions are the same?
Thanks,
Shawn
silver7 is offline   Reply With Quote
Old 10-19-2009, 11:04 PM   #2
silver7
silver7's Avatar
Re: Help - 12 bolt rear swap for 71 C10 4X4
ttt
Old 10-19-2009, 11:35 PM   #3
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
I don't think the '85 will have a 12 bolt- unless someone swapped it in, it should have a 10 bolt. either way, as long as it is the same gear ratio, it can be made to work. I have a '75ish rear under my '68. You have to move the leaf spring perches in closer, move the shock mounts and swap park brake cables. Check the yoke for u-joint size too.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
