Old 01-17-2003, 10:28 PM   #1
scull67
scull67's Avatar
interior rear cab opinions?
After moving your gastank, what have you done to the rear of the cab to finish it? Has anybody used the roddoors rear cab cover? Any ideas and PICTURES would be appreciated. Thanks
Hoboken, N.J.(home)/ Washington, D.C.(work)
scull67 is offline   Reply With Quote
Old 01-18-2003, 12:14 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I re-installed mine.
(sorry...had to be a smart ass)
Oh, I ment TTT.
Old 01-18-2003, 12:23 AM   #3
Riles72
speakerbox material works great!
The guy that did my interior had some speakerbox material. My interior is black, so it worked well. The stuff is a thick felt type material, so it streches and forms to the surface really well. We had already put sound deadener in it, so the stuff formed over the back of the cab really well, plus it moulded around the indentions that the tank was bolted too. It wasn't that expensive, but it's looks great!
Riley
72 Chevy short stepside
350/350
tilt, vintage air a/c
sunset Orange Metallic paint
Early Classic 2.5/4 drop
eagle series 211 wheels
Riles72 is offline   Reply With Quote
Old 01-18-2003, 10:56 AM   #4
mtdave2
newly minted old timer
mtdave2's Avatar
because the stock seat doesnt fold down, your limited on what you can do. the best option is electronics i guess. if you get a modern seat then id use it for storage, tools ect.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 01-18-2003, 11:01 AM   #5
Shane
Shane's Avatar
I plan on using the Roddoors rear cab cover too .... but man, they are sure proud of their peices ... kinda expensive to be nothing more than molded ABS plastic. Sorry, didn't mean to crawl up on the soap box here.
Shane is offline   Reply With Quote
Old 01-18-2003, 11:25 AM   #6
scull67
scull67's Avatar
Thanks for the replys. Yeah shane, roddoors prices are high. One reason I was looking for alternatives. I plan to use a dynamat type insulation. The carpet will cover the floor but if I insulate the rear I thougt the rear cab cover would be a good solution. Riles, I like the idea of just upholstering right over it. Do you think I could do that with vinyl to match my seatcovers? Or I guess I could cover the rear cab cover in vinyl? Just thinking out loud. Any other ideas are welcome.
Old 01-18-2003, 11:57 AM   #7
jay6891
Car Knocker
jay6891's Avatar
I thought all factory seats would fold after taking the two bolts off the rear of seat and leaving the other two for a pivot. That is what I did to mine on my 68. It was a striped down version, radio delete,six w/3 on the tree.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 01-18-2003, 12:48 PM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
My factory seat folds forward. I dunno if it is broken, or the previous owner modified it to fold. My gas tank is still back there, so it really dosne't need to fold forward.
In a old Classic Trucks issue i had, they had a series in which they restored a '68 CST. They put the gastank under the bed. In the cab, they boxed in the cab corners with plywood, and made a platform on the cab floor. Then they covered everything with carpet, and set a storage tray out of a '90's Chevy truck on the platform.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-18-2003, 01:07 PM   #9
mtdave2
mtdave2's Avatar
really? thats cool.
69 k10 Suburban
Old 01-18-2003, 03:51 PM   #10
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
some seats did fold is what I was always told
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 01-18-2003, 06:18 PM   #11
scull67
scull67's Avatar
Good ideas. I like the storage tray idea. I have the 67 buckets with fold down center so the tray could be at that level with access through the center. What did the tray look like. Anyone know the dimentions? I will have to go junkyarding.
Old 01-18-2003, 06:31 PM   #12
XXL
Seņor Member
XXL's Avatar
You probably wouldn't want to do vinyl right over the rear sheetmetal. Vinyl tends to amplify any and all texture in what it's covering. So much so that when I used to do vinyl back in my car audio installer days we swept up the shop before starting, because just little flits and sawdust getting underneath it will cause a bump to show through. If you want to do vinyl, I'd recommend you first cut a panel to fit back there... maybe masonite or lauan board, either of which would be flexible enough to wiggle back there. A second trick is to use 3/16" headliner material as a padding before you cover in vinyl. Not only does this soften it up a bit, but it hides some of the aforementioned problems.
Good luck,
Kenneth
XXL is offline   Reply With Quote
Old 01-18-2003, 06:35 PM   #13
lukecp
lukecp's Avatar
The tray had a storage box on the passenger side (for a jack?), and the rest of it was a maybe a 3" deep tray. It was about as wide as the back of the seat. I wish my scanner was working so i could scan the pic........
Old 01-18-2003, 10:10 PM   #14
Longhorn Man
True, some seats folded, but most did not. seems the earlier ones that were stripped down got the folding one.
The trick of removing the bolt will work, however, if you have good threads on your seat, it'll rip the vinyl that covers all that hardwear. Also, the seat will have to lean on the back wall of the cab to stay upright, which is not a problem onless you are short...or untill the wife gets in to drive your rig. Once the seat is slid up, it reclines too.
Another problem I found (the P.O. did this on the GMC) is the seat back will rub the arm rest on the door that is not opened, it did it so hard that it actually ripped the arm rest on the passenger side door.
I found a 69 C/60 in a local yard that has a stock flip forward seat, in black un-torn vinyl...it looks real booring with no scroll patern, but I am thinking it may look better than the stupid indian blanket seat cover many of us are so familiar with.
Old 01-18-2003, 10:16 PM   #15
BIG ORANGE
BIG ORANGE's Avatar
I got the same problem,I got a new 95 60/40 chevy seat and I have removed the gas tank so I need to do something there,I have aheadliner with 4 speakers in it so I got enough sound,what does the roddoors cab insert look like what is there link?
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 01-19-2003, 10:06 PM   #16
scull67
scull67's Avatar
Roddoors is www.roddoors.com Tee is no pic of the 67-72 cover "dano" but there are pics of others. Let me know what you think? Dave
