Old 10-18-2009, 09:21 PM   #1
fdbdw
fdbdw's Avatar
fuel sending unit removal
Need some guidence on getting the sending unit out, I played with it a bit but almost bent part of it, any tips or tricks will be appreciated, thank you
fdbdw is offline   Reply With Quote
Old 10-18-2009, 09:37 PM   #2
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Re: fuel sending unit removal
Very easy. First remove your seat,next unplug the wire for the sending unit.
Next there is a lock ring you can use a screw driver on that holds the sending unit in. Lay the head of the flat head on the ring and tap it counter clock wise picking the screwdriver up and going to a differnt spot until the ring just pops out. Now just lift up on your sending unit and manuever it out of the tank. hope this helped......................
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 10-18-2009, 11:31 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a brass drift is the prefered tool over a screwdriver. Less damage to the locking tabs and less sparks.
Old 10-19-2009, 12:33 AM   #4
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
LHM is right unless you relish taking a trip to the moon via the Chevron Supreme rocket!
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-19-2009, 01:45 AM   #5
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Probably want to have the cap off as well, pressure and a gaping hole dont mix...
screamin_c10 is offline   Reply With Quote
