Old 10-18-2009, 10:10 PM   #1
62 Bowtie
62 Bowtie's Avatar
angle strips
how have you guys replaced the angle strips in your bed mine seem to be rusted on are there rivits I already cut all the bolts that I could see and they still dont budge for some reason I cant post pics
62 Bowtie is offline   Reply With Quote
Old 10-18-2009, 11:00 PM   #2
chevytrucknut61
chevytrucknut61's Avatar
Re: angle strips
They are spot welded on. The corners should go over the top of the old ones.At least I've seen some that do. I took mine off and my bedsides are warped some what. New ones do not attach to the bedsides.
http://rides.webshots.com/photo/1126...54302821swdZif
Later, Ben
chevytrucknut61 is offline   Reply With Quote
Old 10-18-2009, 11:21 PM   #3
62 Bowtie
62 Bowtie's Avatar
Re: angle strips
what did you use to remove them
Old 10-18-2009, 11:35 PM   #4
chevytrucknut61
Re: angle strips
I used a spotweld remover (a 3/8 drill bit) being carefull to only go thru the strip.
Old 10-19-2009, 07:29 AM   #5
LILRED66
LILRED66's Avatar
Re: angle strips
A spot weld cutter will avoid drilling through the bed side. After cleaning and prepping the bed side, I would spot weld the new edge angles back in place.
LILRED66 is offline   Reply With Quote
