Ford torino housing ends on 12 bolt rear end brake swap
My truck is a 68 C-10 short wide. I have a narrowed factory 12 bolt rear end with moser axles 5 on 4 1/2 bolt circle and torino style housing ends.
I want to put disc brakes on my rear end and have heard that a rear disc set up from a ford explorer is a direct bolt on? Caliper bracket bolt pattern etc..Just want to know from someone that has first hand knowledge or experience, if this is indeed a direct swap or what modifications if any are needed. Also what years of explorer work? Thanks Last edited by DanCam; 10-18-2009 at 10:22 PM. |
70 Chevrolet=Obsession
Re: Ford torino housing ends on 12 bolt rear end
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
I always heard to use mid to late 90's cadillac rear calipers because they have the built it parking brake thing. Then you could still have the same bolt pattern.
1972 Chevy C-10 Lowboy 1972 Chevy K5 Blazer Hi-boy 1948 Plymouth Club Coupe |
That's right, it's Copper!!
Check this http://www.currieenterprises.com/ces...E.aspx?id=1920.
And this.http://www.currieenterprises.com/ces...E.aspx?id=2085
Tom: ![]() 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
