Old 10-18-2009, 10:54 PM   #1
dropped65c20
dropped65c20's Avatar
light switch?
Got a question for you guys out there. How do you go about removing the light switch knob from the switch itself. I have done it once on accident and now that i want to do it i can't remember how.
65 c20 - Shes's rough but she's a diamond in the rough
00 Mustang GT
07 Honda CBR600RR
dropped65c20 is offline   Reply With Quote
Old 10-19-2009, 12:10 AM   #2
slepysal
slepysal's Avatar
Re: light switch?
there is a little spring loaded buttom on the side of the switch,
disconect the battery and press the button and pull the switch knob out
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-19-2009, 12:14 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Re: light switch?
Exactly what Slepysal says. On some switches, you may need to pull the knob to the on position before pushing on the little spring loaded button, and on some switches the button may be on top.
Old 10-19-2009, 07:25 AM   #4
LILRED66
LILRED66's Avatar
Re: light switch?
Pull the light switch knob out, reach under the dash and depress the spring-loaded button, push the knob to the off position and then pull the knob and shaft out of the light switch assembly. Then you will need a wide flat screw driver to remove the chrome dash bezel nut. It unscrews and now the switch can be dropped out of the back of the dash bezel. Now you can remove the factory connector from the switch and free it from the dash.
To install reverse this process, but just insert the pull knob and shafter into the installed switch all the way and it will be secured. Be patient because some are very easy to remove and some are not so easy to remove. They all come out the same way, so take your time and it will come out.
LILRED66 is offline   Reply With Quote
Old 10-20-2009, 08:10 PM   #5
dropped65c20
Re: light switch?
thanks guys
00 Mustang GT
07 Honda CBR600RR
