10-19-2009, 04:07 AM | #1 |
Edelbrock 1406 question
hey guys i'm new here. and my question for you is, will the stock accelerator cable, dedent cable, and throttle return spring work on this carb? i ordered the adapter plate for the manifold, so i'm good there. and is there anything else that needs to be adapted for this carb? thanks, i'm looking forward to the wealth of knowledge the people on this site possess!
10-19-2009, 08:42 AM | #2 | |
Still plays with trucks
Re: Edelbrock 1406 question
I had to cut the throttle cable bracket in two right over the vacuum port for the brake booster and add a small piece of metal to give the bracket the right bolt spacing to fit. You may be able to use the secondary mount holes to get it to work but I used a Holley pattern heat shield under mine so I was limited to the Holley pattern bolt locations. You may not have to modify anything other than your fuel line. Get the tight fitting fuel inlet line with integral fuel filter that Edelbrock sells. It is a slick piece and makes routing the fuel line much easier. |
10-19-2009, 06:13 PM | #3 |
ok i picked up the adapters for the throttle and dedent cables. now i'm wondering about the return spring and throttle cable bracket? do i have to buy one? or can will the one from the q-jet work?
10-19-2009, 08:49 PM | #4 |
BAD BOW-Silverado XST
10-19-2009, 11:42 PM | #5 |
i don't have cruise control, and i did get the adapter for the trans kickdown cable. i plan to just use the return spring from the q-jet, but where should i hook it to on the manifold, or valve cover? also can you give me a link to where i can get a throttle cable bracket for cheap
10-20-2009, 12:16 AM | #6 |
www.jcwhitney.com has it the cheapest. I think I paid $22 for it. Other places charge $35 for it.
My motor has a lift loop it. Post a picture of your engine from the top. We can suggest a location based on available brackets. |
10-20-2009, 08:57 AM | #7 | |
Using the stock Q-Jet mount bolt locations it should fit without any modifications. |
