misfire
Engine is a 350. It tends to misfire when idling or at low rpms or low load situations. Tends to get back on cylinders at app.2300-2400rpm. Varies with load, more load- less misfire. Sounds like only one cylinder is misfireing. I have check all sparkplugs but they look all the same. Any suggestions where to go next??
67 c10 Short Step 350/th400 daily driver 69 Camaro work in progress ![]() |
Re: misfire
I was going to say a fouled plug but you already have that covered. Do a compression and leakdown test, that one cylinder might have bad rings or a burnt/stuck valve or something
'72 cheyenne super step, '05 long bed gmc |
Re: misfire
Is your ignition system in good working order? Wires, Rotor, Cap, Points? If you are at all unsure, I would spend the $120 to replace with new HEI
__________________________________________ Sean 1972 C20 2005 4Runner ![]() |
Active Member
![]() Join Date: Jul 2007
Re: misfire
I'd do pretty much what has been recommended... Try to isolate the cylinder if you can. If you can't then this is what I did. Of course you don't have to do them in this order. The misfire started about 2-3 months after I repaced the plugs.
Did a compression check- checked good on all cylinders. Replaced dis cap and rotor-checked for burn marks or arcing on the old one but wasn't sure of condtion so got a quality replacement. New points- again just wanted to be sure. Got the better ones. Plug wires- I actually tested the old ones for arcing by misting them with a water bottle at night. You can see the arcing if they're bad. I replaced them anyway because they looked old. Checked for vacuum leaks and adjusted the carb for to make sure it wasn't too lean. After all of the above it still would misfire. I put the old plugs in and the misfire stopped. Went and replaced the plugs with a different brand and no more problems. One of the new ones had gone bad... ![]() Last edited by 68gmsee; 10-19-2009 at 07:10 PM. |
Hollister Road Co.
Re: misfire
I would change the timing up or down a few degrees and adjust the throttle accordingly. See if the miss fire changes rpm. That would let you know if its carb or ingnition or valve train. If it stays the same then Its either ignition or valve train. If it changes its carb. if not back off the rockers 1/4 turn and check again. If it changes its vales or adjustment
If its still there its ignition. Test the wires with an ohm meter. Check that the gap is .035 for points or .045 for electronic. Put a vacuum gauge on it and see if the needle bouces. If so its a valve issue. |
Hollister Road Co.
Re: misfire
