Old 10-20-2009, 04:31 PM   #1
Mike Quillici
Temperature Gauge
Hello. My 72 350 barely registers on the temperature gauge, even after the truck has been running for a long time. I replaced a melted section of wire that was laying up against the header, but it still barely rises off the cold mark. Which is more likely to be the culprit, the temperature gauge, or the sender? I'm going to double check to make sure that the thermostat is not stuck open tonight. I don't think this would be the problem, since the truck never seems to get up to operating temperature. Any ideas???
1972 Chevy C-10 ~ 188,000 miles give or take
Mike Quillici is offline   Reply With Quote
Old 10-20-2009, 04:39 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Temperature Gauge
Don't be surprised if that is just where it is running. When everything is in good shape, these trucks run pretty cool. Mine would run between the bottom line and the second line on the gauge all the time. In 105° weather, it MIGHT get a hair over that second line, but that's about it.
Oh, and the T-stat was not stuck open, I had plenty of heat in the colder weather and it ran just fine.
69GMCLonghorn is offline   Reply With Quote
Old 10-20-2009, 05:03 PM   #3
Mike Quillici
I didn't realize that they typically ran so cool. Do you happen to know what a typical operating temperature is in degrees? Eventually I'm going to install an aftermarket gauge with actual numbers on it, but I haven't gotten around to it yet.
Old 10-20-2009, 05:15 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
My stock 350 runs at 190 degrees.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-20-2009, 06:04 PM   #5
69GMCLonghorn
I have ALWAYS run a 160° thermostat in all my old vehicles. Mine ran right at or just below the thermostat regardless of the weather. They just don't need to run hotter than that. There will be people to argue this, I'm sure.
If you find that you don't get enough heat out of it in the winter, you could drop in a 180°. I've run mine in weather right around freezing with the 160 and never had a lack of heater output though.
Old 10-20-2009, 06:10 PM   #6
cparman
sharp as a marble
With the key on and the engine not running , you could ground the sending unit wire to the engine somewhere. If you do this the temp gauge should go full hot. If it does, then everything is working ( electrically) as it should. If this is the case, then you might have a thermostat that is stuck open, or not have one at all.
cparman is offline   Reply With Quote
Old 10-20-2009, 06:16 PM   #7
Mike Quillici
Cool. I will give that a try. If it does go full hot, then the problem could either be with the sender, or the thermostat, right? Thanks!
Old 10-20-2009, 07:56 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
None of mine or my son's Chevy trucks with the stock gauges shows very much temperature with the 350.
I am sure an after market gauge would be more accurate and probably read in the 180-190 degree range.
I normally run a 180 degree thermostat in our trucks even my '92GMC K-3500 with a 454.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 10-20-2009, 09:39 PM   #9
Mike Quillici
I just cracked open the thermostat housing, and I now know why my truck appeared to run so cold. It wasn't there. So, I picked one up, and installed it. I just want to make sure that I got the orientation right. I installed it with the spring down, into the intake manifold, and the point pointing up, into the housing. Is this correct? Thanks!
Old 10-20-2009, 10:24 PM   #10
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
yes that is correct
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
