Old 10-20-2009, 06:36 PM   #1
lks dcvn
lks dcvn's Avatar
Newer Weatherstrip - Door won't close...
I installed the 88-98 Dodge Dakota weatherstrip on the passenger side of the cab - worked great - no issues, no binding - little tight - but the door closes correctly.
I then go to install it on the driver side - no dice. Door won't shut all the way - it will latch - but it look like it is ajar.
I figured that the door needed to be aligned and after making that attempt I figured I would just use the LMC repop stuff that came with the truck since it was thinner (I thought)...I went and got the 3m black weatherstrip adhesive today and then installed the weatherstrip...PITA for one person.
I then went to shut the door and it does the same thing - binds just before closing...
I gave up for the day to eat dinner and get some stuff done in the house so I figured I would ask you all about what I need to do to get this door shutting like it should.
I will heat the weatherstrip up tomorrow with a hair dryer to see if I can get it more pliable, but it will take some serious persuasion to get the door shut all the way (not sure if the hair dryer will do it).
I can get pix tomorrow of what I am working with if that will help.
Thx.
lks dcvn is offline   Reply With Quote
Old 10-20-2009, 06:39 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Newer Weatherstrip - Door won't close...
I used the press on door weather strip from GMC Paul's, was a PITA to get the doors shut. Had to slam them for a while, didn't feel like adjusting the doors. Took months for them to break in, but they seal great. Bump for you.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-20-2009, 10:44 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
How did you try to align it? If you didn't loosen the front hinge bolts and move it out a little you may have to do that. Just mark around the hinges with a Sharpie so you know where you're at. You should have at least two people and a floor jack to do this.
LockDoc
Leon
Old 10-21-2009, 07:55 PM   #4
57larry
what's the lowdown on using Dodge weatherstripping? thanks, Larry
57larry is online now   Reply With Quote
Old 10-21-2009, 08:18 PM   #5
Rack Man
That Dodge weatherstripping is basically the same design as the original stuff....except its the push-on type.....No adhesive required....It seems the jury is till out on it though....some guys swear by it and others hate it....I recently went and picked up a couple different sets from my local pick a part just to check them out and they fit awesome and look great but they made it nearly impossible to close the doors....There are some tricks that some guys use (like heating them up) and it does take time to break them in but i'm not sold on it yet...JMO......I wish I could find a more plyable set that are the push-on type!
RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 10-21-2009, 11:48 PM   #6
70duramax
put the window down a bit and try again if closes easier it just needs a little break in time. when i restored my 70 mine did the same thing, too much air pressure or some damn thing after bout a month didn't have any problems
70duramax is offline   Reply With Quote
Old 10-21-2009, 11:57 PM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
The worst area for holding up the doors is at the bottom of the front of the vent window, right where the dash is. Moving the door back a hair and out a hair can sometimes alleviate this. Every set of seals I've ever put on my truck have always looked awkward and crushed funny after a few years of use in that area.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-22-2009, 12:19 AM   #8
Rack Man
One tip someone told me about for new seals is to rub a little die-electric grease around the entire seal....just a light film....suppose to help keep em plyable and aid in closing and break-in????....Haven't tried it yet but I am just ready to install my new seals and I'll be giving it a shot!
RM
Old 10-22-2009, 01:36 AM   #9
QKENUF4U
QKENUF4U's Avatar
love the newer style push on.... and yes it was a SLAM to get it shut.... but man did it seal when it did shut....
QKENUF4U is offline   Reply With Quote
Old 10-22-2009, 04:58 AM   #10
72CST4x4
It's only a minor addiction
72CST4x4's Avatar
I used S-10 door seals on my '70 and they work great. I will never go back to the glue on type. The doors were hard to shut for a long time, but worth it. They seal better and stay in place.
72 Blazer CST 4x4
72 Suburban K-10
72 B.B. 402 C-10
70 K-10 4 spd
1970 GMC 2500 with 24K actual miles
Current project- 69 GMC swb
72CST4x4 is offline   Reply With Quote
Old 10-22-2009, 09:45 AM   #11
hotrod 80
mini truck racer
hotrod 80's Avatar
I used the 88-98 Chevy fullsized truck . Doors never shut right with them and they never broke in .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-22-2009, 10:38 AM   #12
johnechi
johnechi's Avatar
I used the glue in type from Brothers. They fit well. The drivers side door is a little tight, closes well. The passenger side is tight also.
I had to adjust the striker plate slightly, and I have to push on the door a little when locking it, but overall they work well and the doors no longer rattle when I go over bumps.
johnechi is offline   Reply With Quote
