Old 01-18-2003, 01:24 AM   #1
mikep
Used to have a truck
mikep's Avatar
Summit torque converter
My clutch bellcrank ripped apart the other day . Probably has something to do with the fact that its at a funky angle as its a small block in the big block position ( 2" rearward ) . Good for me I had another bellcrank sitting around. Anyway I pretty much decided to replace the CR 4 speed with a TH 350. Has anyone used one of summits 1800-2200 stall speed torque converters? I called the tech support at summit and they told me they are just repackaged B&M 2400 holeshot converters and if I needed any extra info I should contact B&M. Has anyone used one on our trucks. At $104 its a hard price to beat.
No truck :-(
mikep is offline   Reply With Quote
Old 01-18-2003, 11:37 AM   #2
crazy longhorn
Fabricate till you "puke"
I havent tryed that one, or the B&M converters, so really couldnt comment. I run a TCI breakaway in the longhorn(adv stall 24-2800), & it flashes right to 2800 behind my 383. The converter was $190 a couple yrs ago. They also offer the verter with anti ballooning plates for nitrous(I think about $50-60 more). Good luck....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-18-2003, 12:29 PM   #3
blue_69
someday
blue_69's Avatar
i have a B&M 2000rpm (i think its a holeshot if i remember correctly) on my truck and i havent had any problems. I dont have anything else to compare it to though.
Click Here to search ebay for all 67-72 parts
My 72 CST blazer build
72 CST Blazer 4x4
67 2wd swb ( project onion crate )
86 4x4 lwb plow truck
40 x 60 foot barn to work on all this stuff
blue_69 is offline   Reply With Quote
Old 01-18-2003, 01:42 PM   #4
bigjimzlll
bigjimzlll's Avatar
advertised stalls on inexpensive converters are not very accurate..so many things factor in the stall, its impossible to give a true stall number..things like: Torque(cam and compression) gear ratio,tranny,weight,Tire size all contribute to how the stall is achieved...on my truck I have a custom stall converter..when it was behind the hopped up 283, it would stall at 2100rpm...behind the 355 it stalls at 2600rpm and flashes at 2900..for a nonperformance set up the summit should work just fine.
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-19-2003, 02:50 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have a B&M 1900 stall in my GMC...bought it used from Fast68...have had no troubles from it at all.
Old 01-19-2003, 06:26 PM   #6
LT-102
What do it meant when you guys say a torque converter "flashes" at a certain rpm. Thanks
LT-102 is offline   Reply With Quote
Old 01-19-2003, 07:55 PM   #7
bigjimzlll
bigjimzlll's Avatar
theres a second b4 the converter fully engages(for lack of the right word) the rpm surges a little higher than the normal stall..some racers time this flash to leave on..its usually a few 100 rpm above the advertised stall
Jim
Anderson,CA
Old 01-19-2003, 09:06 PM   #8
Jefe
Jefe's Avatar
I bought a Hughes 3000 stall from a swap meet guy for 40$ put it behind about 400 horse..not a problem. Before that I was looking at the Summit Converters an decided to go with the B&M, rather have a name-brand that specializes in tranny's. Only wanted to do it once.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed
-1968 Chevy SWB = numbers matching 307/Truck 4 speed.
-1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC
-1972 Chevy Nova = 2 door/412 Small Block
-1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything.
Jefe is offline   Reply With Quote
Old 01-20-2003, 12:43 AM   #9
orionwy2002
had summit holeshot in a th400 behind a 396 in a 79 c10
had no problems when i sold te truck with a 350
the guy i sold it to seemes to be happy
Orion
80K10Scottsdale 350/th350/205 d44/14bff locked 35's
97 blazer 4x4 daily driver
orionwy2002 is offline   Reply With Quote
Old 01-20-2003, 02:09 AM   #10
mikep
mikep's Avatar
That probably would be the case but I called once to summits tech support with a question about their converters. The guy didnt know the answer so he gave me the number to the manufacturer. It was B&M . He told me they are just repackaged holeshot converters sold to Summit under contract from B&M
Anyone here ever used a Vega converter. I remember using one behind a 400 horse small block with a TH400 in a 69 camaro . My first car 20 years ago. Slipped like hell up to 3500 RPM but once that thing caught it caught hard. Damned near ran it off the road first time I pulled it out of the shop and stomped the gas . Took a second to remember to let off the gas.
No truck :-(
Old 01-20-2003, 02:39 AM   #11
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
I just got the summit 2600-3200 converter in my truck.(as in about 6 hrs ago) Flashes to almost 4000RPM and slips like crazy, but that's what I was going for. Sure makes the truck launch off the line though(when i can get it to stick).
Don't know about long term, but it sure works good now.
-Jesse
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
