Old 10-20-2009, 10:42 PM   #1
greyghost86
Bent frame
Hey guys Ive got a problem....
While I was in the process of tearing down the '86 I found the front frame horns bent. Can anyone give me some measurements or somewhere to get the factory specs.
The sad part is the truck was put on a frame machine but the guy that did the work really jacked it up.. Thanks for the help.. Buddy
greyghost86 is offline   Reply With Quote
Old 10-20-2009, 10:55 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Bent frame
This page should help you...
http://www.chuckschevytruckpages.com/framespecs.html
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 10-20-2009, 11:02 PM   #3
greyghost86
Re: Bent frame
Thanks man I'll check it out
Old 10-21-2009, 01:17 AM   #4
CreditGod
Re: Bent frame
if its not done perfect it will dog leg when driving down the road I got a long wheel base frame that you can have
CreditGod is offline   Reply With Quote
