Old 10-20-2009, 11:42 PM   #1
cstm68
cstm68's Avatar
bagging my 68.
im going to start bagging my 68 in the next few weeks and im not shure how to do the rear.
for the front i will be using upper plates with lower cups and 2.5'' drop spindals.
my question is do i need to monster notch the rear to get it to sit level?
i want to do somthink custom with the rear bags because i dont want to put them in ware the coils spring comes out. i want to do somthing with a braket on the axle tube and add a crosmenber directly obove it.
so will i need to monnster notch is and cut the bed, or can i just use a bolt in c- notch?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 10-21-2009, 12:01 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: bagging my 68.
To get it level in the front you will have to do a larger notch and cut the bed. The c-notch will still leave you with a slight rake. Personally I like the rake and will be doing the c-notches on mine only, but it's definitely a personal preference thing.
IMHO if you are going to go through cutting the bed floor and doing a big notch, I would run custom inner fenders and rear wheelwells so you can drop it that extra few inches...or get front and rear dropmemembers
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-21-2009, 11:03 PM   #3
cstm68
cstm68's Avatar
Re: bagging my 68.
anyone have some pics?
Old 10-22-2009, 08:55 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
Re: bagging my 68.
This truck has spindles and bags in the front, 2" blocks and notch in the rear and bags...this is on stock style steelies with I believe stock height tires
Here are two that are on 20's with the same setup to give you an idea how low you can go on 20's. The tires are a little larger than the overall stock height but this would give you a better ride and looks nice with the extra "meat" of the tire.
And last, but not least, IvelDesign's sweet 69 longbed he recently sold...in action
Spindles, blocks, and a c-notch...He allowed the pumpkin to slide up a hair into the wood bed so it's a little lower (1" or so) in the rear than you'd get with a stock bedfloor.
Old 10-22-2009, 09:51 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: bagging my 68.
You can go this low with the bags on the stock trailing arms and not cut the bed. If you want it lower you will need a step notch and cut the bed.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-22-2009, 08:46 PM   #6
cstm68
cstm68's Avatar
Re: bagging my 68.
does this truck have a small c notch, how is the front set up??
Old 10-22-2009, 08:57 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
Re: bagging my 68.
Same setup as the blue truck with lower profile tires
Old 10-22-2009, 09:06 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: bagging my 68.
That truck was built by n2billet and went by the name of Lucy. It only had a small C-notch that was owner built. He did do some modifications to the inner wheel wells in the rear, but the floor of the bed was not cut.
The front was dropped spindles, stock A-arms, bag plates and cups.
Articles-
"Refining Sierra"
Old 10-22-2009, 10:24 PM   #9
DZL1
One day.....
DZL1's Avatar
Re: bagging my 68.
Heres mine. My setup goes as follows, Front: 2.5 drop spindles, top bag plates, bottom bag cups cut 1 inch. Rear: 2" lowering blocks, bolt in c-notch, no upper or lower plates. Wheels are 15" rallies on 235 70/15. Picture is aired out. Hope this helps.
DZL1.
DZL1 is offline   Reply With Quote
Old 10-23-2009, 09:03 PM   #10
Rochlow
Re: bagging my 68.
DZL1.
Love the stance on this.. I always say three things make or brake a truck. Wheels, tires and suspension....
Rochlow is offline   Reply With Quote
Old 10-24-2009, 12:03 AM   #11
DZL1
One day.....
DZL1's Avatar
Re: bagging my 68.
Rochlow, thanks for the compliment!
DZL1.
Old 10-25-2009, 08:48 PM   #12
cstm68
cstm68's Avatar
Re: bagging my 68.
DZL1.
wow i love the stance, do you have any pics of the suspention??
Old 10-27-2009, 11:50 PM   #13
DZL1
One day.....
DZL1's Avatar
Re: bagging my 68.
cstm68, Thanks for the compliment and let me see what I can dig up and I'll post them.
DZL1.
Old 11-20-2009, 09:39 PM   #14
drewfever1020
Re: bagging my 68.
i love that stance im going with the same setup yessssssssssssssssssssssssssss!
drewfever1020 is offline   Reply With Quote
