Has anyone used this company?
Quick Fuel Technology: A guy told me about them he had used them on a few Carbs. You send it to them,they call you and get some information. He told me he would never rebuild another one. He said when you get it all you do is bolt it up and set idle. Any other feedback ? Thanks
BOHICA
Re: Has anyone used this company?
Never heard of them, but I am interested as well. Did your friend mention what they charge for the service?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
What exactly do they do?If it`s rebuild carbs,I have a local place I`ve used for years and I just bolt them on and go.That`s how it should be.I do fine tune my carbs,but a new or rebuilt carb should be set to fire up a motor of the bench.
They do a complete rebuild do all of the adjusting when you get it all you do is set idle. He is a mech. and he said he would not touch one again after using this company. I think he said the charge is 150.00 and also for this person to pay it it must be worth it.
Well I got mine back today, They blast,tumble,recolor the Carb, and went thru it completely replacing everything taking back new and it looks new I'll try to post pictures before and after. I'm putting it on Friday.
![]() Last edited by gmcdude; 11-18-2009 at 08:29 PM. |
Before
Active Member
quick fuel has been around for quite some time
The specialize in taking Holley carbs and modifying them for your application. They ask for a ton a technical information and build, and wet flow the carb to get it dialed into the combination that your motor will require. Great folks to speak with regarding tech
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
