"THE GREEN GOBLIN"
TH400 Transmission GURU's Please help.
I have several questions My th400 was put together with the wrong yoke so it caused some problems.
#1. My first question is does this little copper ring that slides over the yoke supose to fit in the Transmission Tailhousing snug or loose?-Mine fit's loose What is stoping it from moving forward and falling deeper in the Tailhousing and bouncing around? #2. 2nd question Where can I buy a cheap non fancy Transmission Tailhousing if I need one? #3.Question 3 my input out put shaft( I hope thats what its called) looks all scratched up & worn because of the yoke being the wrong one Does it look like I need to replace it? #4. Question #4 Do I have the correct color speedometer gear for my transmission and rear end set up it seemed a little off when I drove it, I have a 12 bolt with 373's.? I just had a new drive line made with the correct fixed yoke and I am short on funds you can say I am broke so I am hopeing I can get away with just replacing the Transmission Tailhousing if I need to thanks Pablo....Here are some photos #5. Also what can I use to clean the inside out when I get ready to close it up can I use brake parts cleaner? ![]() ![]() ![]() ![]() Thanks guys............... ![]()
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 10-21-2009 at 03:35 AM. |
"THE GREEN GOBLIN"
Re: TH400 Transmission GURU's Please help.
More pictures..
![]() ![]() ![]() And of my truck ![]() thanks again.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Hollister Road Co.
Its a press fit bushing. If its flopping around your tail shaft housing needs to be replaced., You can get one at a trans shop or junk yard. The shaft should be replaced at some point but It should be ok for awhile as long as your not romping on it. I don't know if the gear is correct
Never Ending Projects
I agree, a replacement tailhousing is most likely going to be needed.
Looking at the pic of the output shaft (input shaft is the one on the converter side), it is seriously worn to the point it has a dip in the surface. It is way more then scratches. My guess is, if you put everything together, this area will cause some slop in the yoke as it moves and will eventually wear out the bushing/yoke. How long it would last, no idea? As for the speedo gear, you need to find out what you have currently (the orange gear) and find the chart that tells you what rear end ratio it is for. Keep in mind, if the tire size is not stock, you'll have to do the math to figure out which one you will need.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
"THE GREEN GOBLIN"
I picked up a replacement tailhousing for $35.00 at a local transmission shop & they even installed the bushing and seal for me
![]() Thanks for the help once again..
Great. Glad you got one to work.
Agree, to replace the shaft, you end up needing to disassemble the whole transmission.
