Old 10-21-2009, 01:21 PM   #1
Sicboy
Sicboy's Avatar
Drop height questions
I've searched but haven't found a definitive answer.
What is the most I can drop the front by using just drop spindles and shorter springs? Im not interested in bagging.
What is the most I can drop the rear using shorter springs and blocks only? What height spring and what size block should I use? Not interested in notching the frame or using bags.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 10-21-2009, 01:44 PM   #2
SIR
SIR
SIR's Avatar
Re: Drop height questions
...HOWDY FROM SOUTHERN OREGON! after everything setteled down I found a 4/4 drop with springs & spindles works just fine....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 10-21-2009, 03:00 PM   #3
63whoopie
you can go lower; I have seen drop spindles in both 2" and 2.5" sizes, and front springs that drop 1", 2" and even 3" 's. For the rear, I have found the 1- 5" drop springs... maybe more, I can't remember. Obviously, the guys here know more about it, since I have only priced it out and been studying it.
LMC has the 2.5" spindles, and springs 1" & 2" front, with 3, 4, & 5" drop for the read. They recommend a notch kit for anything over 5", and with 4" and over, a set of their shorter shocks.
This is an example of the types of availability. LMC, Brothers, Chevy Duty, Harmons, etc. all sell these things, I believe (my memory of my parts catalogs list.)
63whoopie is offline   Reply With Quote
Old 10-21-2009, 04:50 PM   #4
Nailz
Shlong bed club
Nailz's Avatar
63 whoopie is right on the money. Im at 5.5/7 and its about as low as you can go. The ride is good but if im going to fast and hit a bump i rub up front, and getting out of driveways i think i scrape my crossmember. Mines notched too.
Nailz is offline   Reply With Quote
Old 10-21-2009, 05:52 PM   #5
chevyguys
I Got it BAD!
chevyguys's Avatar
I would agree that 5.5 and 7 is about as low as you can go... Mine is 4.5" front and 6" rear. front is 2.5" spindles and 2" springs, Rear is 5" springs and 1" block (this way I still have some spring travel. Rear is not c-notched.
Early Classic Enterprise's has great parts and service. I made the mistake of going through CPP. My buddy went through Early classic Enterprises and his stuff was of a much high quality for about the same price. CPP's rotors and calipers and bearings are junk. For the most part everything else was ok.
ECE also has stance photo's online here:
http://www.earlyclassic.com/Tech.asp...=Stance+Photos
Build Thread: http://www.chevyguys.com
chevyguys is offline   Reply With Quote
Old 10-21-2009, 06:35 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've done 3 inch spindles and 3 inch springs in the front for a 6 inch total. It's very low and required a good bit of attention to not hitting the front crossmember on things.
In the back, a 6 inch spring is no problem.
Old 10-22-2009, 01:32 PM   #7
70 Suburban
Rods
If you lower the wheel opening in the front it will look like a massive drop.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 10-22-2009, 05:58 PM   #8
Roadhammer
Roadhammer's Avatar
SO, Not to high jack but its on topic. If you wanna be low and you plan on buying springs and spindles later but you are say......ummmmmmm....whats the word.....ohya Impatient...What are your thoughts on heating up the spring how bad does this turn out.
Obviously ghetto and redneck...But would it suffice for the Low needs of a broke person?
LOL
Jory
Roadhammer is offline   Reply With Quote
Old 10-23-2009, 12:15 AM   #9
MXmaniac
MXmaniac's Avatar
LOL
Jory
Don't heat them, cut them.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
