Old 10-21-2009, 01:46 PM   #1
Northern lights
What'll it take?.
What'll it take to lift a short fleet box complete with wood floor off the frame?. Can 2 guys do it or will we need four?
Northern lights is offline   Reply With Quote
Old 10-21-2009, 01:55 PM   #2
terd ferguson
terd ferguson's Avatar
Re: What'll it take?.
I used to have an International Scout II with the removable hard top. I loved to have it off in the summer, but it was a hassle to get three buddies over at the same time to help me take it off. I rigged up four eye bolts in the ceiling of my garage screwed into studs. I used ratchet straps hooked into the eye bolts at one end and the hard top on the other end. Then just work the ratchets to raise the hard top. You could do the same thing with the bed if you need to get it off by yourself. Just a thought. I've never lifted a bed personally, so I don't know how many guys it'll take to do the hard way. Sorry.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 10-21-2009, 03:17 PM   #3
DPowers
DPowers's Avatar
More is always better. Unless you have to buy the beer....
DPowers is offline   Reply With Quote
Old 10-21-2009, 04:15 PM   #4
4dranch
Shloooooong bed member #2
4dranch's Avatar
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 10-21-2009, 04:20 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I had two real big friends come over and we lifted my short bed with OLD wood, water soakes and such. It wasnt easy for us 3 to make it happen but we did it and it also wasnt moved very far from the truck. I like the ratchet strap idea. If you are in a shop, then acome-along with straps could work if attached on an ibeam at the ceiling.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-21-2009, 06:22 PM   #6
shortbed70
shortbed70's Avatar
4 makes it easier but still heavy,I'm just a little guy at 180lbs if that helps.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 10-21-2009, 07:20 PM   #7
LILRED66
LILRED66's Avatar
One guy can do it like this.
LILRED66 is offline   Reply With Quote
Old 10-21-2009, 07:28 PM   #8
Slow Build
Slow Build's Avatar
We gotta talk. lol.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 10-21-2009, 07:45 PM   #9
LILRED66
LILRED66's Avatar
That is too funny. My truck came from Overland Park, KS and the white bed came from Omaha, NE. Your's is a more desireable swb fleetside with a big back window, compared to my lwb fleetside small back window.
Old 10-22-2009, 01:37 PM   #10
Northern lights
I have 2 ton picker with a 14' reach that I'm going to mount on a 1ton that would lift it easy enough and the ratchet strap idea would work. My only concern is that i don't want to mark the paint in and around the stake pockets, that's why I was considering removing it by hand. It might be best to figure a way to lift it with the picker without marking the paint. Any thoughts on THAT would be welcome
Thanks guys
Old 10-22-2009, 02:03 PM   #11
63 & 64 Bowties
and a few others
I traded beds on my 63 & 64. Three of us did it with old wood (partially) still in and tailgate off. If I remember right, one guy on the headboard and one on each side at the rear. One thing I do remember; it was heavy. (wear gloves)
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 10-22-2009, 02:07 PM   #12
lakeroadster
They are pretty heavy, go with 4 guys. Remove the rear tires and drop the rear diffential as low as you can that way you won't be lifting the bed up over the tires.
On Tuesday I lifted my '65 short step bed off (again, for about the 5th time) and used a 2 ton engine hoist with the mast extended out as far as it will go.
To prevent hurting the paint remove the bed mounting bolts, pull the bed back about 3 inches and then install some long eyebolts through the original (2) front ad (2) rear mounting holes.
I remove the tailgate and run the lift in from the tailgate end of the truck, not the side. That way if the bed rocks around a bit it won't hit the side of the bed.
Good luck and don't blow your rear o-ring seal, if ya know what I mean.
lakeroadster is offline   Reply With Quote
Old 10-22-2009, 02:46 PM   #13
62 Longbed
62 Longbed's Avatar
Wow !!!! Great idea !!! Now I know what I'm gonna use my cherry picker for ... Insted of it sitting in the garage ... Plus it is hard to get people to show up ... Beer or no beer ....
62 Longbed is offline   Reply With Quote
Old 10-22-2009, 04:08 PM   #14
Northern lights
Good idea
To prevent hurting the paint remove the bed mounting bolts, pull the bed back about 3 inches and then install some long eyebolts throught the original mounting holes.
GREAT IDEA
Old 10-22-2009, 11:01 PM   #15
jonathan-m
When I picked up a fleetside bed, we got it done with 3 guys. One of those guys was literally twice the size of me and the second guy though
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
