![]() Join Date: Dec 2008
81 Tilt Steering Column Question
We're in the process of restoring an 81 GMC Sierra 1500 1/2 ton, 305 motor, automatic. Somewhere along the line, someone has broken the bowl that surrounds the turn signal/tilt wheel, etc. I am able to find a repair kit for 88 and up, but nothing for an 81. Is there anything that is interchangeable? Any assistance would be appreciated.
#2 | |
Re: 81 Tilt Steering Column Question
Also look at 3/4 ton and one ton trucks and various car models. GM used parts across many different product lines.
My Truck's not leaking its marking its territory! Last edited by 87Bob; 10-21-2009 at 03:55 PM. Reason: More info |
Tilt and Non-tilt housings do not interchange. I've bought a repair kit on eBay before for around $35.00. There is also a website that has the parts you need, but I don't know the url right offhand. Housings are pretty much the same for many years and models until they went to column mounted dimmer switch. Also check local body shops that do theft recovery repair. They will have a supplier, or even a GM part number. Good luck.
ty for the Replys
