Old 10-21-2009, 04:07 PM   #1
420am
420am's Avatar
I found a set of Motown 220 heads for $400.. opinions on my application.
I guess they were used in a drag car for a few passes. I had a leaking head gasket so I pulled my heads and I'm pretty much freshening up my top end. My lower end is all stock though. These heads are set up for a solid roller cam/lifters but they're swapping out the valve springs to stock springs so they work better for my application. I do plan on adding a cam and all of that good stuff in the future. Will these heads work well in in my application? These heads are around $1100 new.
My application:
350 cid
Headers
Edelbrok 1406 Carb
Aluminum Intake
Oreilly's Crate Motor
Stock Internals
Specs on the Motowns:
220 cc runners
64 cc chambers
2.05 x 1.60 severe duty valves
New Comp 10 degree retainers & locks
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 10-21-2009, 04:19 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: I found a set of Motown 220 heads for $400.. opinions on my application.
I think those 220 cc runners are going to kill low end torque on a stock motor.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-21-2009, 04:49 PM   #3
turp mcspray
turp mcspray's Avatar
Assuming you have a 350...way too big on the intake runner. Stock heads are in the 157 range and vortecs are 170. More suited for HEALTHY 400. It does sound like a decent deal though.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-21-2009, 07:24 PM   #4
SCOTI
SCOTI's Avatar
That's a good price for just about any aftermarket heads. Buy 'em for that $400 & trade across for some heads better suited for your current set-up (or put them on the shelf for a future build).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-21-2009, 08:40 PM   #5
420am
420am's Avatar
He has a set of Vortecs that have quite a bit of machine work done to them and they're fresh that he said he'd let go for $400 also but I don't want to have to buy a new intake.
Old 10-21-2009, 09:19 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
You'd be better off with the Vortecs. There's a Summit branded Vortec intake for about $140.
Beat it to fit,
Old 10-21-2009, 10:09 PM   #7
SCOTI
SCOTI's Avatar
Or.... buy the Motown 220's @ $400 & swap 'em for some built vortecs w/intake. Someone out there will have what you need. Like I said, that's a good price if they're legit (no hacking, un-trashed, etc...).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-21-2009, 10:22 PM   #8
420am
420am's Avatar
Hmm. I think I'll try to talk him down on the Vortecs.
Old 10-24-2009, 03:31 PM   #9
420am
420am's Avatar
Went with the Vortecs
now I just need to pull the press-in studs, tap for screw-in studs, then buy some guide plates, centerbolt valve covers and a Vortec intake.. dammit might as well throw a cam and lifters into the mix while I'm at it. haha
Old 10-24-2009, 07:02 PM   #10
MikeB
MikeB's Avatar
You done good! Those 220 ports were WAY TOO BIG.
Your truck just picked up 30+ horsepower.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
