Old 10-21-2009, 09:07 PM   #1
jmking9
jmking9's Avatar
The best way to Generate more Vacuum?
I just got my CPP Booster and MC installed this afternoon, and finally completing my disc conversion.(had pics but cant get them to load) I knew I would probably be short on vacuum, but I'm really short. My motor only generates about 8-9 inches of vacuum.My question is, what has everyone with big cams used to generate vacuum? Is a vacuum canister enough, or do I need an electric pump. Any Input?
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 10-21-2009, 10:05 PM   #2
mixermike
mixermike's Avatar
Re: The best way to Generate more Vacuum?
a vacuum canister works for me.
mixermike is offline   Reply With Quote
Old 10-21-2009, 10:30 PM   #3
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I said screw it... going slow (when vacuum is low), I'm not moving fast enough to really hurt, and I just push harder on the pedal.
At speed, you have enough vacuum to stop.
But yeah... a canister, or a pump.
You could also go to the hydromatic power brakes and not worry about vacuum.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 10-21-2009, 10:36 PM   #4
Jim_PA
What are the engine specs? Timing? vacuum advance? Seems pretty low unless you've got a pretty huge cam
Jim_PA is offline   Reply With Quote
Old 10-21-2009, 10:55 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
It's been a long time since I checked mine, but I thought my 350 was running at around 18-20 @ idle. I checked it 'cause I thought I had a leak, but I didn't. 8-9 seems really low to me. I will admit to NOT knowing a lot about engines though...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-21-2009, 11:04 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Condition of the engine has an affect on vacuum also. If it's old and long in the tooth, it may need some valve or ring work.
68gmsee is offline   Reply With Quote
Old 10-21-2009, 11:07 PM   #7
69TowRig
My brother runs a dual-diaphragm booster and uses a vacuum accumulator on his 502BB Chevelle.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 10-21-2009, 11:38 PM   #8
highperf4x4
What are your engine specs and what style of intake?
highperf4x4 is offline   Reply With Quote
Old 10-22-2009, 02:58 AM   #9
lost wages
lost wages's Avatar
hydroboost all the way, it will stand y our truck on its nose. Its what i did after spending a bunch of money trying to fix it cheap. http://www.hydratechbraking.com/Hydr...D926717302BC91
lost wages is offline   Reply With Quote
