Old 01-18-2003, 08:19 AM   #1
Troy 82
Question Catalytic converter
I plan to replace my exhaust in a couple of weeks. The catalytic converter on there has an air tube but it's capped off. The truck didn't come with an air pump from the factory. So, the new converter I get doesn't need an air tube correct? Thanks!
Troy
1982 Silverado
Troy 82 is offline   Reply With Quote
Old 01-18-2003, 09:37 AM   #2
Prerunner1982
Prerunner1982's Avatar
that should be correct. when i replaced the cat on my now non-existant exhaust it didnt have an a tube on it. but....now with no cats i dont have to worry about it..
and welcome to the board... pretty darn good guys....and gal(s) around here..with load of info to share...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-18-2003, 01:53 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
It sounds like someone has put another cat on. The stock cats didn't have the tube. All you need to get is a regular 3 way cat. I recommend a high flow model. Steer clear of the factory cats. They are expensive and don't flow very well. I would go with a 3" in/out cat for best performance.
And welcome.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 01-18-2003, 09:38 PM   #4
Troy 82
Thanks guys for the welcome. I'm familiar with alot of the names here, I used to post at CT once in awhile.
Troy
1982 Silverado
Old 01-19-2003, 01:47 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Try a Catgo (?) from Summit Racing. I have one and it does fairly well. It was easy to blow out too. Yes it was accident.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-20-2003, 01:25 PM   #6
PHOENIX
Good question. I have been meaning to ask the same. I have the A.I.R. system on my truck and keeping it when I do my exhuast (not by choice, by law). So when I get a cat I need to get one without the little tube?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 01-20-2003, 09:11 PM   #7
swervin ervin
Correctamundo Edrica.
Mike
1985 Chevy C-10
Old 01-20-2003, 09:37 PM   #8
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Is it required in TX??
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 01-21-2003, 03:13 AM   #9
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I think 84 (83?) and older do not need cats. I didn't on mine.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 01-21-2003, 12:44 PM   #10
PHOENIX
Heres another question. Should I have the cat welded in place?
Should I have the muffler welded in place?
If I didnt have you guys to ask Id weld the cat in place and bolt the muffler. Just case I need to change mufflers later for some reason. What do you guys think is the best?
Old 01-21-2003, 01:12 PM   #11
swervin ervin
Eddie,
the easiest thing, and best way of doing it is what I'm going to do, as soon as I get my distributor back. I bought some Summit header collectors, 3" in my case. I have all my stuff welded to stop leaks. Well as you know, I can't remove anything without cutting if off. When I drop the y-pipe, it will only go as far as the crossmember. I going to have the collectors added in front of the cat so I can take it apart and remove the y-pipe. You could also add these to the muffler inlet just as easy. Clamping the tailpipe just don't cut it. It will still leak and you can't get it off very easy either.
Mike
1985 Chevy C-10
Old 01-21-2003, 10:16 PM   #12
bigd65
bigd65's Avatar
i am wondering if the cat is what is what is wrong with my truck. i got under it the other day and hit the exhaust and i could hear the cat rattle. it aint but about 2-3 years old. i wonder if that is where all the problems are stemming from.
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 01-22-2003, 08:08 PM   #13
Troy 82
I've looked at summitt site & the Catco converters. The three I came up with to get are CTO-6906, 8006, 9006. The first one is 14" long the other two are 16.5". The aftermarket cat I have on there now is 16.5" long. From what I read the difference in the 8006 & 9006 is one has an air tube. Summitt tech said CTO-6906. I called a couple muffler shops around here that carry Catco & the tell me CTO-9006. They said the 6906 is like a stock cat & the 9006 is High efficient. I'm leaning towards the 8006. What do you guys think?
Troy
1982 Silverado
Old 01-23-2003, 05:01 PM   #14
bigd65
bigd65's Avatar
welll i would get the HI-FLO cat
2017 Chevy Tahoe
Old 01-23-2003, 05:34 PM   #15
messed up c-10
RHCP afficianado
messed up c-10's Avatar
What about the Dynomax converters from Jegs? Are they any good?
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 01-23-2003, 05:37 PM   #16
messed up c-10
RHCP afficianado
Is that a state law? I thought that all trucks after 78 had to have cats. on them unless you live somewhere where there arnt emissons laws.
~Ryan~
Jack Johnson
