tunnel ram intake question-help-
im curious if anyone on here is running a 67-72 with a tunnel ram? if so post some pictures as im curious where it will sit in relation to to the firewall and how far out of the hood it will stick on my 67. also does anyone have experience with them as far as knowing if an hei dzzy will work or do i need a smaller unit?
thanks for any input
1967 c-10-built smallblock, backed by m-21, lowered 2005 silverado-tint, exhaust, lift, 35's 1964 c-10 shortbed project |
Re: tunnel ram intake question-help-
anyone running a tunnelram???
hei wont fit. my buddy runs one but no hood. there is some pics on my myspace. it fits fine on the fire wall.
myspace.com/southtacomaalleyrally |
sorry your myspace isnt working for me, are his carbs mounted with the bowls front to back or side to side? does it stick out of the hood? and do you know what brand it is? sorry for all the questions but i really want to get this thing on.
heres mine for reference, ![]()
Dude that is HUGH! Wow Get r done wit that... oh man
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
motor exploder
'ProstreetC10' is running a tunnelram with a BBC. maybe pm him and see what he's got?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
thanks guys il try to pm prostreetc10
#8 | |
i ran one on a '69 Camaro more than 25 years ago. That won't help you a bit about hood clearence though....I ran a points type distributor though, HEI was fairly new back then. LOL
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
My Carbon Footprint
Ah yes.......should I put a tunnel ram on my 67-72 with a BBC..........
Can I get a "Hell Yes!" You and I have a couple of different issues here and I'll cover them both. I'll post a bunch of pics but explain them here. Assuming that our motors are sitting in the same place (I used factory '68 BBC mounts), that tunnel ram is going to put the carbs REAL close to the firewall/cowl. Where we have some differences is that I'm running mine sideways and you are running yours end to end. I only have the main body to worry about but you also have the thinkness of the fuel bowl too so that should make it even closer! ![]() Just look at the pics and let me know if there are any other questions you have. I can't get any new pics because she is all tucked away for the winter. Hope this helps P.S.....For those of you "pros" really looking things over, the rubber fuel lines are going bye-bye. That was just to get it going this year. I'm doing a complete custom routed steel line job on it next year and it's going to look VERY sanitary. ![]() |
Righteous!
thanks prostreetc10 im stoked that its going to to actually stick some of the carbs through the hood, as i figured just the stacks would show. i definately understand the firewall clearance issue as that is where i figured i would find most of my problems. the hood issue sounds rough but i guess il find out when i start cutting how bad it really is. thanks for everyones input i cant wait to get this done
My Carbon Footprint
Just remember......measure 15-20 times and cut once!!!!!!!
#13 |
no problem
#14 |
I have a 69 c10 with a tunnel ram,2 660 marine center squirts. My front end is a one piece tilt i built, ihave no problems with fit or anything.thanks project 69
#15 | |
My Carbon Footprint
Hey....you're kinda new around here. I'd love to see some pics of your truck and that one piece tilt front end. I've kicked that concept around the garage a couple of times. Post 'em up please!!!! Also curious how those 660's are working. They were never really intented for the street. No power valve and 1:1 linkage. Do you have them modified or are they stock? Thanks! |
#16 |
look up sneakysnake, he has a great front tilt job on his truck.
fwiw, you cannot run a typical large cap hei but they make small cap systems, gm used a stock small cap on the tbi motors. you can also convert your points dist to a hei pickup for $65. |
#17 | |
My Carbon Footprint
Thanks...I'll look him up. Right on the HEI. I'm running an MSD 85551 with a 6AL and love it. |
