01-18-2003, 10:12 AM | #1 |
I miss this truck.
Opinions on cab mounts
It is my understanding that there are 2 types of replacement cab mounts. One is like original, and the other slips over the originals. Is there any thing wrong with these "slip-ons for a daily driver? Will having that original mount underneath there cause the slip-on to rust from the inside out?
Thanks, Tynee
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
01-18-2003, 10:55 AM | #2 |
You can use either one depending on the damage that needs to be repaired. The slip-on one can be used if it covers the area that needs repairing and you would be able to seal it so that rust would not occur. It is probably better to replace the whole mount but it is not necessary in all cases.
Jiim |
01-18-2003, 12:03 PM | #3 |
RUST THROUGH
The owner b-4 me put a slip on rocker cover over the original rocker now they r both rusted through.If it were me I would cut the rust out and do it right or at least cut the rust out and see what is left then put the cover over.The rust will eventually come back.It all depends if you want to do it right or wait a few years then do it right.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
01-18-2003, 07:43 PM | #4 |
Oh, you mean cab "supports". I replaced mine a few years ago, here are some pics from the job. http://groups.msn.com/Alsplac/cabsup...nw?albumlist=2
I had to use slip-ons for the rear supports, they were the only ones available at the time. They seemed to be 14 ga. "satincoat" steel (sort of a fine galvinized coating). I yanked the old ones anyway, or what was left of them . The slip-ons fit nicely, and I later coated them with a heavy rubber based, spray-on undercoating. But like everyone else, I don't like the idea of having rot underneath perfectly good metal, it can be contagious and spread. The front supports were OE style, 12 ga. steel and a good coating of gloss black already applied.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. Last edited by Southpa; 01-18-2003 at 07:47 PM. |
