help help asap
wondering if this will work on a 66 c10 to give me disc front and drum rears and power steering . and possaible 350 for a spare . thank you it is a 1979 chevy van . if link dont work.
http://reno.craigslist.org/pts/1431770423.html thank you in advance and i need to know asap if i could as he is sure to send it to junk heap. ![]() |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: help help asap
I can't say for sure, but if it has the 5 x 5 bolt pattern wheels then it should work for your swap. Some of the older 1/2 ton vans had 5 x 4.75 wheel bolt pattern. However I don't know if the crossmember is exactly the same as a pickup, I think it might be wider, so you might have to just use the control arms and out. The steering boxes on those vans can be an oddball, I believe they turn opposite of a pickup. The rear ends in vans are wider than pickup rear ends, so that probably won't work for you. Of course the engine and trans will be no problem. If it has a tilt steering column, that is a desired column for swapping into the older trucks.
Hollister, CA.
![]() Join Date: Sep 2006
Re: help help asap
I say get it for cheap and "Cheech and Chong" it !!
(sorry, couldn't resist) ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Junior Member
Re: help help asap
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() |
#5 | |
Re: help help asap
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield ![]() .......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS..... ![]() ![]() |
Re: help help asap
well i am thinking let it go to the crusher in the sky , and the search continues. i was hoping most if not all the sussipoin would swap . thank you all .
Re: help help asap
THat will work great for your upgrade
