Old 10-22-2009, 01:59 AM   #1
5W0P3
C6Z Wheels on my 68' (5x4.75 bolt pattern)
I hope i'm posting in this in the right area as I didn't see one specifically for wheel questions but since it is to my 68' I'll post it here.
I'm looking to put the new c6 z06 wheels on my 68. I know this is a 5x4.75 (small chevy) pattern but a couple things come to mind. I know the backspacing on the 19x12 wheel is a lot more than what these trucks were designed for so how would I get the face of the wheel where it needs to be on the front and the rear? Right now, i have 6 lug all the way around, but will be going to 5 in the next couple days and lowering the truck at the same time.
anyone else gone to the 5x4.75 pattern and ran ZR1 wheels or anything else like that?
TIA!
5W0P3 is offline   Reply With Quote
Old 10-22-2009, 04:03 AM   #2
OARNGESI
OARNGESI's Avatar
Re: C6Z Wheels on my 68' (5x4.75 bolt pattern)
Depending how much differencce the backspace is you can try a set of these http://cgi.ebay.com/ebaymotors/5x4-7...Q5fAccessories
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 10-22-2009, 04:36 AM   #3
5W0P3
That's what I was thinking, but i'm going to have to use something similar to get from 5x5 on the truck to 5x4.75 on the wheel. I want to say there is about 4 MORE inches of backspacing on the z06 wheels. I can't run a 4" spacer I dont think...
Old 10-22-2009, 04:45 AM   #4
OARNGESI
OARNGESI's Avatar
i think they come up to 2 inches maybe you can find a wider rearend like from a 88-98 and get a inch or too on each side not really sure on the front at all just a thought
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 10-22-2009, 10:09 AM   #5
danman987123
danman987123's Avatar
i have a 68 swb....had 6 lug all the way around....all i did was take out the 6 lug rear end....picked up a 97 z28 camaro disc rear end cut off all the brackets for springs, etc and mounted right up....was not even much different in the width of the rearend. when i bolted it up it sat good in the rear like it was built their not added, after it was bolted.....WAAALA....i had 5x4.75 disc brakes on the rear. then up front i will buy the big brake kit from mcgaughy's with the 5x4.75 pattern and bolt on whatever 5x4.75 wheels i want later.....just my opinion...but i would do it again well worth adding disc and newer rear end with 5x4.75 pattern all at once...
danman987123 is offline   Reply With Quote
Old 10-22-2009, 11:15 AM   #6
smoky02
Location: Sunny, Florida, some might call it South Alabama
Or you could just take the factory 5 X 5 discs to a machine shop and have them drill them 5x 3/4. That's what my dad and I did. But I have no idea what to do about the back spacing. Also what is the actual back spacing on those wheels?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 10-22-2009, 11:20 AM   #7
CoachSwin
CoachSwin's Avatar
Either of ya'll selling the 6 lugs that were taken off. I'm in the market for 6 lug rims and tires.
69 Chevy C10 SWB Stepside 350 SBC 700r4
CoachSwin is offline   Reply With Quote
Old 10-22-2009, 11:53 AM   #8
5W0P3
I will be selling my 6 lug rally wheels (black with chrome beauty ring and centercaps when i'm done - can get pics)
I like the f-body rear end idea. But I still think that the backspacing is going to be way off.
Old 10-22-2009, 02:18 PM   #9
danman987123
nope sorry i will not sell just rims/tires but will sell entire rolling chassis. .....its a rolling chassis.....6 lug drum all the way around....no rust. was sandblasted and painted 2 years ago....and also have a crappy old long bed sittin on it that can go with it.....i just kept my cab and front end and bought a swb frame and started over so all i saved from my original truck was cab front end and title....
Old 10-22-2009, 02:34 PM   #10
Ackattack
Ackattack's Avatar
the newer 4th gen 10 bolt rearends are weak units. Lots of guys have broken them with stock power (me included)
I don't like the looks of newer car style wheels on these old trucks, they have too much backspacing for my taste for what a classic vehicle should have (JMHO)
Ackattack is offline   Reply With Quote
