10-22-2009, 02:49 PM | #1 |
Light body work/painting in a garage???
'71 C10. Want to strip surface rust with a grinder and apply what it takes to stop it from coming back. All I have is a tiny compressor and no "spray" equipment. I know I need to neutralize the rust left in the pits of the metal after grinding with a "metal prep" type of product from PPG or another maker then cover with an enamel primer from a can. Can an inexpensive spray gun be used to do this? I've never done any car painting or real spray painting so I don't really know the process of doing it right. Anyone have advice for an amatuer or suggestions on equipment or paint/primer products to stop the rust?
10-22-2009, 04:05 PM | #2 |
member #16
Re: Light body work/painting in a garage???
Welcome to the board. You can find your answers in the "paint and body " forum
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
10-22-2009, 04:28 PM | #3 |
here in my town they sell a handheld sand blaster at harbor freight for $20 and it holds like a cup of sand. i would sand down to bare metal then hit the rust with this instead of using chemicals to kill the rust because who knows if that stuff really works. they say they test it and things like that but theres always a possibility it might come back. best $20 a spent was on that little sandblaster. it works perfect. i even used it when i did frame work to paint my frame
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
10-22-2009, 04:29 PM | #4 |
and i also used a cheap gun to shoot primer.. and it wasnt worth it. i dry sprayed so bad it feels like i sprayed liquid sand paper. even if i tryed to set the gun it didnt work out..
