got a new diff ... anything i need to know ?
ok so i ran the stock diff in the 79 k10 out of fluid and scored the gears. so i found a 10 bolt out of a 2003 silverado with disc brakes
#2 | |
Re: got a new diff ... anything i need to know ?
Keep fluid in this one
![]() No, seriously, there is nothing to traumatic about swapping axles. I would check the pinion angle of the original before you remove it. A magnetic angle finder on the yoke is all it takes. That way you can weld the new perches with it at the same angle. Obviously, measure carefully to be sure that it is centered. I would change the fluid after the welding. You might also check to be sure that the u-joint is compatible or that there is a adapter joint available before you start.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
make sure the gears match your front axle..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
