Old 10-23-2009, 12:59 AM   #1
SCOTI
SCOTI's Avatar
Custom PHB Mounts?
Anyone make their PHB mount? I'm going to be making mine because of the drop needed (3" below the frame rail) & thought there might be a 'simple' version of something vs. the idea currently rattling around in my noggin.
Post up pics or links for inspiration....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-23-2009, 01:11 AM   #2
LkyDevilz72
LkyDevilz72's Avatar
Re: Custom PHB Mounts?
Well, what exactly is a PHB mount?
1972 Chevy C-10 Lowboy
1972 Chevy K5 Blazer Hi-boy
1948 Plymouth Club Coupe
LkyDevilz72 is offline   Reply With Quote
Old 10-23-2009, 06:15 AM   #3
kev2809
low n' slo
kev2809's Avatar
im guessing panhand bar mount?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-23-2009, 09:11 AM   #4
SCOTI
SCOTI's Avatar
Yes, PHB means Pan Hard Bar.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-23-2009, 02:21 PM   #5
XXL
Señor Member
XXL's Avatar
It's a Panhard bar-- one word. Panhard is the French family's name that owned the Panhard Automobile Company in the early 20th century that invented, and originally implemented the method for controlling suspension geometry. It's pronounced "Pinard" or "Puhnard."
Bonus educational moment: The Watt's Link was invented by James Watt in 1784 (one of the key contributors to the Industrial Revolution, which changed our world forever). His implementation was used on a Newcomen-based steam engine to keep the piston arm roughly centered in its stroke. Contrary to common perception, a Watt's link does not create a truly linear alignment, but rather it follows the straightmost section of a standard logistic sigmoid function or Lemniscate of Bernoulli.
XXL is offline   Reply With Quote
Old 10-23-2009, 05:47 PM   #6
SCOTI
SCOTI's Avatar
I actually knew this. But for the masses on the WWW, it's commonly referred to as a PHB thus my basic break down.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-23-2009, 06:00 PM   #7
jlaird
jlaird's Avatar
never heard of them referred to as PHB...
XXL likes google
jlaird is offline   Reply With Quote
Old 10-23-2009, 09:04 PM   #8
lotik
drag it like you stole it
XXL likes google
or wikipedia.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 10-24-2009, 10:04 AM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Scoti-
I would start with a piece of square tubing, cut one side off it, drill a hole in it for the bolt, viola!
I'm think of something similar to the on in the picture.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 10-24-2009, 12:57 PM   #10
Shane
Shane's Avatar
Originally Posted by lotik View Post
or wikipedia.
or basic Physics and/or Mechanics class in engineering school ...
Shane is offline   Reply With Quote
Old 10-24-2009, 04:42 PM   #11
SCOTI
SCOTI's Avatar
Originally Posted by smashingchuck View Post
Scoti-
The issue w/this is the amount of drop will require some triangulation on a set-up like that. Right now, I've got the 'base' that's the width of the frame rail bottom & it will bolt in where the original was riveted (frame rail & triangulating c.member). I'll prob make some 'tabs' that drop down to the height I need & go from there.
I was thinking maybe someone here might reference something that would boost my brain-storming process.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-24-2009, 07:27 PM   #12
mullit
mullit's Avatar
X 2
mullit is offline   Reply With Quote
Old 12-11-2009, 12:34 AM   #13
SCOTI
SCOTI's Avatar
Got it all finished up tonight. No pics yet cause I need some hardware for a 100% complete installation. I'll post up some pics after tomorrow....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-11-2009, 08:52 AM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
subscribing,...
Keith
Convert to disc brakes.
Old 12-15-2009, 01:30 AM   #15
SCOTI
SCOTI's Avatar
I made poster-board templates for the basic shapes needed & transferred them to .1875 steel . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-15-2009, 01:32 AM   #16
SCOTI
SCOTI's Avatar
Drilled the holes to secure the plate to the side of the frame making sure it was plumb. This allowed everything to be put in place & tacked together . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-15-2009, 01:35 AM   #17
SCOTI
SCOTI's Avatar
Everything temporarily in place to see if I like the set-up . . ....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-15-2009, 01:40 AM   #18
SCOTI
SCOTI's Avatar
I left the camera @ the shop w/the most recent pics. I figured I would @ least get the ones I'd already down-loaded from the camera on here so you could see my crap.
I'll finish up tomorrow w/the final bracket.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-15-2009, 01:40 AM   #19
kev2809
low n' slo
kev2809's Avatar
you have cartoon handwriting lol. like a comic book...
anyways..
that's looks nice. is it because of your setup to why you would to make those?
-_--_--_ _________
Old 12-15-2009, 01:55 AM   #20
SCOTI
SCOTI's Avatar
anyways..
The Panhard bar works best when set-up parallel @ ride height to minimize the side shift as the suspension cycles.
The OE frame brackets put the Panhard bar too close to the differential cover (both the 65 & 68 brackets) & wouldn't allow the bar to be parallel @ ride height. This bracket solved both issues & can be adjusted w/possible future changes....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-16-2009, 12:45 AM   #21
SCOTI
SCOTI's Avatar
Mounted & 'cleaned' up so it's less bulky....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-16-2009, 12:50 AM   #22
texastrendz
where does it hit the rearend at, it looks like it goes rail to rail, im missing something
texastrendz is offline   Reply With Quote
Old 12-16-2009, 12:51 AM   #23
FnLow69
FnLow69's Avatar
Very nice, looks clean and purpose built.
FnLow69 is offline   Reply With Quote
Old 12-16-2009, 12:59 AM   #24
lolife99
lolife99's Avatar
Very NICE!
Keith
Old 12-16-2009, 01:17 AM   #25
SCOTI
SCOTI's Avatar
The pass side attaches to the back of the truck arm & the OE drivers side bracket attached to the bottom of the frame. The OE mounts put the bar right against the differential cover & too close to the frame (not level @ ride height).
This mount moved the centerline of the mount further back (about 1") & dropped it level. Since it's adjustable, I can get it perfect once the truck is loaded (just in case my ride height measurements aren't 100% correct).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
