Old 10-23-2009, 09:07 AM   #1
C10Slim
CPP Lowering Blocks
Does anyone know if CCP lowering blocks are wedged to create proper pinion angle? I put mine in late last night and looks like the pinion is awfully high. I was thinking maybe I didn’t pay attention and put them in wrong? It's either that or I need to find some wedges to correct it.
C10Slim is offline   Reply With Quote
Old 10-23-2009, 09:14 AM   #2
SCOTI
SCOTI's Avatar
Re: CPP Lowering Blocks
The CPP blocks are not wedged. There are 'pinion shims' available for truck arms if necessary..... www.stockcarproducts.com. Look under Rear Suspension; truck arm spring mounting parts.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-23-2009, 09:24 AM   #3
C10Slim
Awesome thanks for the quick reply SCOTI!
Old 10-23-2009, 09:28 AM   #4
dznucks
dznucks's Avatar
Mine are supposed to be here today and i ws going to throw them in this weekend.
Are pinion shims needed? i thought i read that they were not needed.
I have the CPP drop xmember and i am going to use 1.5" cpp blocks.
dznucks is offline   Reply With Quote
Old 10-23-2009, 09:33 AM   #5
C10Slim
I have the CCP drop member and the 2" blocks and the angle is defiantly off.
Now I am thinking I should have gone with the 1 1/2" blocks because of the scrub line, anyone want to trade blocks?
Old 10-23-2009, 03:25 PM   #6
kev2809
low n' slo
kev2809's Avatar
do all trucks need pinion shims?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-23-2009, 05:44 PM   #7
SCOTI
SCOTI's Avatar
No. Not all trucks need them. My 68 swb w/bags & 1.5" blocks didn't use them & I logged 5+yrs of daily use (6K a year min) w/o issue.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-23-2009, 05:55 PM   #8
kev2809
low n' slo
kev2809's Avatar
you basically you wont know until you get the blocks in and drive it around?
-_--_--_ _________
Old 10-23-2009, 07:53 PM   #9
dznucks
dznucks's Avatar
kev...thats the scary part.
i ordered the 1.5" blocks. they were a no show today, no brown truck.
the cpp drop member raised the front of the trailing arms, changing the angle of the rearend. how much i dont know...i dont guess the blocks would change that angle, it would just change the height difference from the tranny output shaft.
Old 10-23-2009, 07:55 PM   #10
dznucks
dznucks's Avatar
damn there aint nothing but texans on this thread.
i'll be in fort worth tuesday for work, austin/dripping springs for the weekend.
Old 10-23-2009, 10:04 PM   #11
kev2809
low n' slo
kev2809's Avatar
hmm, im just gonna run blocks, no drop member for me. i guess ill have to wait and see i guess
lol, i didnt even notice that. there seems to be a lot of us texans on this board
-_--_--_ _________
Old 10-24-2009, 02:07 AM   #12
VA72C10
VA72C10
VA72C10's Avatar
You can correct the angle by flipping the mounts on the factory crossmember, or better yet, if you're bagging the truck, flip the entire trailing arm crossmember...that will flip the mounts and flip the carrier bearing (lwb)
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-24-2009, 05:56 AM   #13
SCOTI
SCOTI's Avatar
There's not really a need for this. I had 2600#/7" bags bolted directly to the truck arm & frame on a swb (1pc driveshaft), 1.5" CPP blocks & used every milimeter of a CPP bolt-in notch. The factory truck arm crossmember was untouched nor did I use pinion shims in over 5yrs of daily use.....
Put it together & see what it needs before you create an issue that doesn't exist.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-25-2009, 09:06 PM   #14
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I had to shim my 72 GMC lb after installing 2" blocks about 6*.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 10-25-2009, 09:25 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
Of course it makes sense to measure out for your specific application. I read 1.5" but was thinking 2 or 3" block which is what most have been doing. If I didn't flip my carrier bearing my pinion angle would have been very bad at ride height with the 2" blocks plus the ECE super trac bar which makes it 2 1/4"
Old 10-26-2009, 07:17 AM   #16
dznucks
dznucks's Avatar
i am going to have to measure the angles when i get the blocks installed.
do you mean you can correct the angle caused by lowering the truck by flipping the x-member? If so the CPP drop memeber does essentially the same thing?
Old 10-26-2009, 08:57 AM   #17
SCOTI
SCOTI's Avatar
Yes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-26-2009, 01:52 PM   #18
dznucks
dznucks's Avatar
cool. thanks scoti
Old 10-26-2009, 04:00 PM   #19
SCOTI
SCOTI's Avatar
With stock truck-arms & flipped mounts, it's possible the arms will come into contact w/the frame sooner on extreme drops (since the front of the arms would be higher). Something to keep in mind.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
