Old 10-23-2009, 11:36 AM   #1
OJ1988
Just a car guy
OJ1988's Avatar
rams horn manifolds
will rams horn style manifolds clear the frame and crossmember on a 69 truck?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 10-23-2009, 11:46 AM   #2
71tahoe
71tahoe's Avatar
Re: rams horn manifolds
Back in 69 the GM engineers seemed to think so.
71tahoe is offline   Reply With Quote
Old 10-23-2009, 12:44 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
If they are the correct ones for that application they will. There aren't all that many different ones but you have to make sure you have the right ones for your truck.
I have a '69 down to the bare frame with the motor in it but it is a big block so I don't think pictures of it would help you.
LockDoc
Leon
Old 10-23-2009, 12:50 PM   #4
my67chevytruck
Under Construction
my67chevytruck's Avatar
I agree with Leon... If you have the correct ones they will clear. with my experience, you will need the ones that angle towards the back instead of dumping straight down The straight dumps will interfere with the starter unless you go with a mini..... ...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-23-2009, 02:47 PM   #5
Arizona oldguy
Arizona oldguy's Avatar
Here are my two cents worth, I am building a 67 short bed using a 72 frame, the 67 has a home grown 327 with the rams horn manifolds, I media blasted them and painted them VHT ceramic coating (came out extremely nice) my ultimate plan are a very good set of shorty block hugger headers, but that is when I replace the 327 with a nicely built 350.
Arizona oldguy is offline   Reply With Quote
Old 10-23-2009, 02:52 PM   #6
50MOTORHEAD
50MOTORHEAD's Avatar
I have a 72 with 350 and my ram horn manifolds dump out the center ,,which would put the header pipe straight into the crossmember. Ya need ones that dump out the rear ,as previously stated.-KB
50MOTORHEAD is offline   Reply With Quote
Old 10-23-2009, 09:02 PM   #7
Sammy
I believe 2 WD Stock all came with angled manifolds and the center dump was a 4 WD aplication.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-24-2009, 02:44 AM   #8
mclairmo
I thought I read that some guys here are running the Corvette 2.5 inch straight dumps with no problems. Dorman makes them new now.
mclairmo is offline   Reply With Quote
Old 10-26-2009, 11:02 AM   #9
gator2511
gator2511's Avatar
They will work on a 4wd truck but I don't think they will fit on a 2wd. I'm running them on my 72 4wd.
gator2511 is offline   Reply With Quote
