Old 10-23-2009, 12:59 PM   #1
Jim_PA
Another good oil thread
Found some info on New-Holland Ambra HSP motor oil -
1.7% Zinc Compounds ~ 1700 ppm
Comes in some good viscosities, I'll start using it.
http://www.viscosityoil.com/nh_mastergold.htm
Jim_PA is offline   Reply With Quote
Old 10-23-2009, 05:03 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Another good oil thread
Probably good stuff, but I'll stick with Mobil 1 synthetic. I get an easy 5000 miles out of it and it doesn't smell burned. Plus, Costco has it on sale this month: $23.99 for 6 quarts... not too bad!
69GMCLonghorn is offline   Reply With Quote
Old 10-23-2009, 08:50 PM   #3
clinebarger
Thanks for the info, got to keep that flat tappet cam alive! Ive been using Lucas zinc plus additive, 1 oz. per quart
clinebarger is offline   Reply With Quote
Old 10-23-2009, 08:58 PM   #4
hayhauler71
hayhauler71's Avatar
What kind of oil are you using your lucas with? I tried using tb zinc plus with rotella t per lucas and lost some oil pressure due to aeration. That's right I pulled over on the side of the road and pulled the stick and it was all foam. I emailed lucas about this problem they said it was caused by overfilling the crankcase. I call this BS because one month later i was told by my shops part supplier that he used the same rotella t and lucas and ended up air chiseling the bearings off his crankshaft.
hayhauler71 is offline   Reply With Quote
Old 10-23-2009, 09:14 PM   #5
KrazyRay
KrazyRay's Avatar
I run Derby Oil in my trailer race truck
KrazyRay is offline   Reply With Quote
Old 10-23-2009, 09:32 PM   #6
Jim_PA
Just another tip... There are other tractor brands they make oil for, and they may have similar additive content, just browse that website, as they make oils for Cub Cadet and many others.
Old 10-23-2009, 09:34 PM   #7
clinebarger
Valvoline Premium Blue 15/40 in my diesel, Mobil 1 10/30 in my 70, cheap stuff 10/30 in the 85 all with the additive. What made me aware of this is the switch in diesel oils from CI-4 to CJ-4 specs the reason being not to damage the particulate filter/catalyst in the new quieter junk they call diesels with zinc and other by-products. and come to find out automotive oils have had less zinc for quite a while.
not only is zinc good for camshafts its is good for the valvetrain
Old 10-23-2009, 10:17 PM   #8
clinebarger
"agricultural, and other off-road diesel-powered equipment" is what it says in the link. i hope its not like off road diesel fuel. dyed & a stiff fine.
Old 10-23-2009, 10:25 PM   #9
bigoletruck
bigoletruck's Avatar
I use mobile 1 in everything i have
My rides
-'96 gmc sierra 4.3
-'98 gmc sierra 5.7
-'85 s10 sleeper *sold*
-'69 c10 show truck/trophy whore
-'59 apache olds 455
-85 720 bagged shaved out of control *sold*
-'83 gmc high sierra
bigoletruck is offline   Reply With Quote
