Old 10-23-2009, 02:13 PM   #1
61TWUK
61TWUK's Avatar
Drop Member question
Ok I know acouple of yal have Drop Members from Porterbuilt...My question is how much do they run? I called and talked to the guy there acouple of months ago and can't remember or find my sheet of paper I wrote all of the info on.... Please help...
1961 Apache
SWB/SBW for now...
Built 327
You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40.
61TWUK is offline   Reply With Quote
Old 10-23-2009, 02:16 PM   #2
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Drop Member question
I'm not sure about the PB, but mine from SD was like 1200. I think they are priced the same. Which version are you talking about though? he has a couple and I know they are priced diffrent.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-23-2009, 02:21 PM   #3
61TWUK
61TWUK's Avatar
I'm wanting the coil over system.. not a big fan of bags I've had them on an S10 before and was'nt happy I'm also wanting rack and pinion!!! thats the main reason for the change and to get rid of the torsion bar system.
1961 Apache
SWB/SBW for now...
Built 327
Old 10-23-2009, 02:29 PM   #4
ruffrida2005
so your talking about the version that excepts the corvette control arms. I haven't seen anyone do it on the torsion bar frames. I would PM Nate. I know he makes them for the older frames.
Paul
Old 10-23-2009, 05:33 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
here are a couple threads on the 60-62 dropmember, looks to be $1425, also looks like there is a 5% discount for site supporters...
http://67-72chevytrucks.com/vboard/s...d.php?t=295367
http://67-72chevytrucks.com/vboard/s...d.php?t=295365
