Old 10-23-2009, 07:29 PM   #1
smith_84c10
smith_84c10's Avatar
lowering question
So would raising the hangers have about same affect as a flip kit...cause a few i know that had flip kits were messing around and took off too quick and the rear end slipped out and messed a few things up..so i want to be able to play around in my truck....so what would you guys recommend?
smith_84c10 is offline   Reply With Quote
Old 10-23-2009, 08:21 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: lowering question
A flip kit will give you more drop, and is easier to do. I would bet the "few you know" either had cheap flip kits, home made flip kits, or they were installed incorrectly. Get a quality flip kit from Bell Tech, Western Chassis, etc....install it correctly, and you won't have any problems.
bigblock73 is offline   Reply With Quote
Old 10-23-2009, 09:12 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
How would the rearend slip out when it is secured with 4 u bolts ? Doesn't make any sense.
Old 10-23-2009, 09:15 PM   #4
3r!c84
Badass
3r!c84's Avatar
another qestion,with a flip kit is there any way to lift it up a in. or 2 with out adding leafs?
i lowered the front and im thinking 5 in the back is going to sit too low,and i dont wanna lower the front anymore to level it out
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-23-2009, 09:52 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Only thing I've ever seen was the rear diff pointing up at the bottom of the bed beause the perches werent welded on the axle tube and it spun on acceleration. Tore up the u-joint, rear brake hose, etc.
--Josh
Old 10-23-2009, 09:56 PM   #6
bigblock73
yeller
bigblock73's Avatar
Adding leafs on a flip wont do anything...because they are now below the axle. All you could do I guess would be to reposition the hangers down on the frame an inch or two..but that would be a LOT of work. I say unflip it and go with shackles and hangers, or lower the front more.
Old 10-23-2009, 09:57 PM   #7
bigblock73
yeller
bigblock73's Avatar
Taller tires in back will help too I guess
Old 10-23-2009, 10:10 PM   #8
fiddy9apache
fiddy9apache's Avatar
ive always made home made flips, as long as the done CORRECTLY there just as good or better as a store bought.
fiddy9apache is offline   Reply With Quote
