Old 10-23-2009, 10:30 PM   #1
SnS C10
SnS C10's Avatar
Question about clearance issue
i have a 79 2wd blazer. not sure but i think it has drop spindles on the front. the tires in front are about 3 1/4" front the top if the INNER fenderwell not the outer fender lip. if i cut 1 coil off, will i have a clearance issue with the tire hitting the inner fenderwell or will it still roll and drive ok besides the stiffer front end? thanks for the help
SnS C10 is offline   Reply With Quote
Old 10-24-2009, 08:27 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Question about clearance issue
Ya you will rub if you hit a big bump if you go any lower..
tvblazer78 is offline   Reply With Quote
Old 10-24-2009, 12:48 PM   #3
SnS C10
SnS C10's Avatar
how about if i remove the inner fender?
Old 10-24-2009, 10:33 PM   #4
tvblazer78
Low & Fast!
tvblazer78's Avatar
If you did that it can go lower then. You can always put air bags on it..
