10-24-2009, 01:39 AM | #1 |
Qustion about 73 Blazer Buckets
What is the difference between the 73 blazer LOW BACK bucket seat and the 72 Blazer bucket seat?
Will the seat covers from a 72 fit a 73? They look the same. BTW, I'm new here. Been lurking for months though. Sooo glad this place is here. Last edited by bradford; 10-24-2009 at 05:14 AM. |
10-24-2009, 05:38 AM | #2 |
Re: Question about 73 Blazer Low back Buckets
Welcome to the 67-72 Truck Board from West Michigan!
If you have a known 72 seat compare them carefully as the differences are minor. If the seats do look alike then the covers will fit. The differences in the foam show up with the covers removed so if you remove the covers you can confirm whether or not the covers will fit. I have seen 73's that have the 72 shape in them. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 10-24-2009 at 05:38 AM. Reason: Spelling |
10-24-2009, 05:44 AM | #3 | |
I dont have a 72 seat to compare. I just picked up a set of 73 lowbacks to put in my 72 swb and I cant find white seat upholstery for a 73!? I can only find white for the 67-72. If I can cut down foam or something minor to make the 72 fit on the 73 I will but I dont even know the dimensions on either. I am actually still in Iraq just buying parts for when I get home. I cant freekin wait to get started on it. |
10-24-2009, 04:59 PM | #4 |
Re: Qustion about 73 Blazer Buckets
Anyone else? Are the seats the same?
10-24-2009, 07:21 PM | #5 |
SWB 4x4 Collector
The foam is difference like said. You can reshape the foam and put the 72' covers on. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-24-2009, 07:25 PM | #6 |
I will take a picture of the Blazer seat and post it. It sounds like you are busy.
Jim PS: Thank you for your service!
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-25-2009, 02:46 AM | #7 |
Thank you very much! I guess I'll order my seat covers then.
More questions to follow.... |
10-25-2009, 05:00 AM | #8 |
Wow. Im not new to forums and I always do a search before I ask the same question everyone else asks but i did the google search on the site and got a hundred answers that I wanted.
This is exactly what I was looking for. Next question is modified bench seat brackets to make the 73 blazer buckets bolt in. I cant find that answer. |
10-25-2009, 10:52 AM | #9 |
If your seats look like the picture then the 72 covers should work.
The 73 Blazers did not have the "hump" like the 72's have where the front part of the seat brackets fasten. To make up the difference the front "feet" are 1" taller then the 72's. Here are a couple of pictures of a 72 bracket measurements. As it turns out the rear "feet" are the same height for both years as measured from the floor up the the track to where the "feet" attach. The front "feet" on the 73 Blazer measure 4 1/2" tall from the floor to the attachment point. The front "feet" on the 72's measure 3 1/2" . Adapting the 73 to the 72 floor is a matter of reducing the height of the front "feet" by 1". Your floor anchors will have to be located to match. Jim
10-25-2009, 01:12 PM | #10 |
These are the seats I got.
Thanks for all the info, Jim! I appreciate it. http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT Last edited by bradford; 10-25-2009 at 01:14 PM. |
01-23-2020, 10:43 PM | #11 |
I have a question. I have a set of 74 K5 low back seats and the 2nd row bench that bolts in. Can I use a 71-72 K5 front and rear upholstery kit to do my seats? I can't find a kit for the 73-75 K5 seats that I quite like.
01-26-2020, 03:56 PM | #12 |
I modified two sets of bench sliders and made adapter brackets so I can use the existing outer holes in the floor and that way both seats are adjustable as well.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear Last edited by 70STOVEBOLT; 01-27-2020 at 01:12 PM. |
01-27-2020, 07:15 AM | #13 | |
The '72 covers fit fine
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
03-19-2020, 08:46 PM | #14 | |
