Old 10-24-2009, 03:28 AM   #1
roofingbloke
Air Bag Tank Size ?
Im in the UK and just about to order my air bag components, however im getting lots of different opinions on tank and compressor size,
1963 C10, Long Fleet,
Small c notch out back, 2" drop spindles up front,
I dont need the air system to go up & down fast, Just need to get her a bit lower when stationary,
I had a 48 Ford with mustang 2 front end with air ride tec bags, 1 gallon tank, small compressor, all worked fine, 2-3 mins to refill tank.
I was thinking the following, 4 X 6" bags, 1 x 3 gallon tank,
thanks
roofingbloke is offline   Reply With Quote
Old 10-24-2009, 08:06 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Air Bag Tank Size ?
I have a 3 gallon tank on my blazer and wish I had a 5 gallon.
I just wish I could have a little more capacity.
Keith
Convert to disc brakes.
Old 10-24-2009, 08:13 AM   #3
roofingbloke
Hi Lolife, Why do you think a bigger tank is required ?
What size pipes are you running.
Old 10-24-2009, 08:34 AM   #4
lolife99
lolife99's Avatar
I am running only 1/4" airlines.
I just want more "switch time" without the compressor running.
Keith
Old 10-24-2009, 09:20 AM   #5
DZL1
One day.....
DZL1's Avatar
I'm running a 5 gallon tank with 1/2" lines and 2 compressors. Truck would lift and drop too fast for my liking so I put flow controls on both the aired up and aired out. Thinking about switching to (2) 3 gallon tanks. Not because of performance, just because I want to relocate my tank and it wont fit where i want it.
DZL1.
DZL1 is offline   Reply With Quote
Old 10-24-2009, 10:02 AM   #6
Naterman35
Im running a 5 gallon tank.. Search ebay for tanks. Mine came off an old city bus. 5 gallon 3 port tank for $11 bucks.
Naterman35 is offline   Reply With Quote
Old 10-24-2009, 10:49 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
One 3 gallon tank is going to be rather small. If it's possible to fit a single 5 gallon, or two 3 gallon I think you will be happier.
If a single 3 gallon is your only option, consider a compressor with a high PSI rating. This will at least allow you to pack as much air in the tank as possible.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-24-2009, 12:16 PM   #8
nastyc10
nastyc10's Avatar
I'm also using a 5 gallon tank with 3/8 lines and 1 compressor. Works fine for what I want.
nastyc10 is offline   Reply With Quote
Old 10-24-2009, 12:22 PM   #9
roofingbloke
Just been on the ridetech website & there kit comes with a 3 gallon tank ?
So i was just thinking there must be a good reason thet all u guys seem to go with 5 Gallon tanks.
Old 10-24-2009, 01:21 PM   #10
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I think a good set up would be a 5 gallon tank and 2 compressors keeps the run time down on the compressors....they suck to listen to...just remeber the comp's are hard on eletical systems they draw like 16 amps each
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-24-2009, 02:40 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by roofingbloke View Post
So i was just thinking there must be a good reason that all u guys seem to go with 5 Gallon tanks.
More tank volume equates to longer, but fewer fill cycles. With a single 3 gallon tank your compressor will have to cycle almost every time you lower and raise the vehicle. With one 5 or two 3 gallon tanks you will be closer to 1.5-2 suspension cycles before the compressor comes on.
I think most will agree that the worst part of an air suspension is listening to the compressor run. I have mine mounted at the very rear of the truck with the filter remote mounted and it's still annoying.
Articles-
"Refining Sierra"
Old 10-24-2009, 04:35 PM   #12
roofingbloke
Reply to Hottrucks, Thanks for the reply. Question one pump runninf for 3 mins drawing 16 amps or two pumps running for 1.5 mins drawing 32 amps ??
Old 10-24-2009, 08:59 PM   #13
Hottrucks
Hottrucks's Avatar
which ever you choose just be sure to wire them acordingly...I have one comp and it it fails I'm stuck at least with two...well you get it
Old 10-24-2009, 09:57 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Be sure if you run two compressors, that you use a relay.
Articles-
"Refining Sierra"
Old 10-25-2009, 08:34 PM   #15
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
You can never have enough. The bigger the better. Depends on the amount of room and your mounting location. I have 2 5gal. tanks and still wish I had more.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 10-27-2009, 02:04 AM   #16
mr mike
mr mike's Avatar
My old s-10 i had had a 5 gal I liked it the comprise would fill it real fast and not get to hot doing it I got all my air ride stuff from Jason at http://www.*****************/
nice guys and great prices
mr mike is offline   Reply With Quote
Old 10-27-2009, 07:56 AM   #17
XtremeBowtie
XtremeBowtie's Avatar
I'm running a gallon tank and one Viair 400C compressor right now. It works just fine. I can raise my truck up once before the compressor kicks on. I'm running 1/2" lines with 3/8" Big Red valves, and a 135/150 pressure switch.
[IMG][/IMG]
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ!
My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342
XtremeBowtie is offline   Reply With Quote
Old 10-31-2009, 09:19 PM   #18
protrash64
Resistance is Futile
protrash64's Avatar
I'm impatient and went with 2 Viair 400's (almost 5cfm IIRC). I originally had a 6gal tank and after filling the compressors would not turn on at all after numerous adjustments. My compressors pull 50amps...so what, you have to wire them anyway..just use some cable...and a big alternator. I used all re7's with 1/2'' line, fyi.
I re-did my set-up with a 5gal tank and 2 re8's at the rear. I used 3/8's line to the back, also, for a little bit more control. After airing up the bags, my compressors now kick on for just a minute to replenish the tank. The re8's really eat more air.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
