10-24-2009, 04:35 PM | #1 |
Drive shaft please help
where can i find a longer drive shaft or a nice well built drive shaft for mudding and ect I bought a truck a while back and it had a lift on it and the guys didnt extend the drive shaft to even everything up! Any advice on where to get one and what kind i should get will help out alot thanks in advance
10-24-2009, 04:57 PM | #2 |
3/4 Ton Rodder
Re: Drive shaft please help
1979blkchevy, try this site. I think they can get you what you're looking for.
http://www.4xshaft.com/index.html Thanks Benjamin.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
10-24-2009, 05:01 PM | #3 | |
10-24-2009, 05:06 PM | #4 |
3/4 Ton Rodder
No problem. I've heard about them on PowerblockTV. I know Trucks used them and I think Xtreme 4x4 did also. I may use them to replace my 2 part driveshaft on my '81 3/4 ton 2wd with a 1 piece to eliminate a vibration from the carrier barring.
10-24-2009, 05:25 PM | #5 | |
The vibration is not caused by the the carrier bearing, so you must have either a slight bend or other imbalance in one of the shafts you already have. A one-piece driveshaft that long will be pretty expensive. The diameter of the tubing gets much larger when they need to be that long. It would probably save you quite a bit to have yours checked/balanced.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-24-2009, 05:38 PM | #6 | |
3/4 Ton Rodder
10-24-2009, 11:05 PM | #7 |
If your truck has the 14 bolt full floating axle then yes you can use a driveshaft from a 73-81 1/2 ton as long as the truck has the same trans as yours does. All that you will need is a trick U-joint so it will fit your yoke. The semi floating 14 bolt uses a shorter driveshaft.
10-24-2009, 11:15 PM | #8 |
3/4 Ton Rodder
I'm going to be changing the fluid in my rear axle, how can I tell if it's indeed a FF?
BTW, sorry for stealing your thread 1979blkchevy.
10-24-2009, 11:34 PM | #10 |
3/4 Ton Rodder
Ah. "I see." said the blind man to his deaf son in the dark closet.
10-25-2009, 05:17 PM | #12 |
Man (Drive Shaft King) In Dallas tx, Custom makes them and they are great at it.
10-29-2009, 05:42 PM | #13 |
10-29-2009, 07:41 PM | #14 |
Sorry I don't think so I looked myself but you may try to look for a shop that does that around you. If you cant find no other way.
87 Chevy R10 LB 02 Nissan Sentra GXE |
