10-24-2009, 06:17 PM | #1 |
Shifter won't go into R or P
Hi All,
While working on my truck today I couldn't get the shift arm into park or reverse. It goes from Neutral to low with no issues. The column is not hooked up to the transmission or linkage so it has to be an internal issue to the column I presume? Column is from a 70 C10. I was thinking it could be the neutral safety switch might be busted, could that be the problem? Thanks, Sam |
10-24-2009, 06:18 PM | #2 |
Re: Shifter won't go into R or P
Are you pulling the lever toward you to go into Reverse and Park ?
10-24-2009, 06:31 PM | #3 |
2scews hold NSS to column take it off and see
or you can try spraying a bunch of lubricant all over all moving parts to see if that frees it up or its also possible the indicator needle sliped out of alignment
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 10-24-2009 at 06:33 PM. |
10-24-2009, 06:47 PM | #4 |
10-24-2009, 06:50 PM | #5 |
Indicator needle is missing but the slot for it is still on the column and that only goes as far as neutral.
10-24-2009, 09:00 PM | #6 |
I am a Referee of life.
Make sure the rod isn't hanging up on something under the truck.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-25-2009, 08:00 AM | #7 |
10-25-2009, 11:03 AM | #8 |
Drive the pin that holds the shift lever in out, & remove the shift lever. Spray WD-40 or equiv. all around in side the hole. Put the lever & pin back in & in neutral pull the lever forward & back. See if it will free up enough to allow you to shift to reverse. If not get underneath to the bottom of the column & there are 2 C shaped clamps with 3 bolts in each one. Remove the center bolts & spray the same penetrant in the holes. Then try working the gearshift forward & back. If this doesn't do it you will have to pull the column & o-haul it.
10-25-2009, 07:24 PM | #9 | |
10-25-2009, 07:27 PM | #10 | |
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
