Old 10-24-2009, 08:15 PM   #1
jdfrmnt
failing smog in az
hi all i have a 70 gmc 1/2 ton 383 eddy intake headers mild cam i pass everyting but idle hc i have allready swaped out the intake carb recuved the dizzy and im out of things i can think of so what are your thoghts any help is good help thanks
jdfrmnt is offline   Reply With Quote
Old 10-24-2009, 08:23 PM   #2
'72customdeluxe
Re: failing smog in az
Hydro-carbons? Tune the carb and get some cheap cats if necessary.
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 10-24-2009, 09:04 PM   #3
QKENUF4U
QKENUF4U's Avatar
full can of acetone in tank.... dropped my co from 23% to 6% and my HC from passing to almost 0 (.96)... idle up a bit (1500) , at op temp and dont sit in line and idle... good luck
QKENUF4U is offline   Reply With Quote
Old 10-25-2009, 01:39 AM   #4
1968CHEVYC10
1968CHEVYC10's Avatar
there was a post like this a few weeks ago, it had alot of good info couple pages long, so if you could find that I'm sure that'd help you out alot. I don't remember the name of it but if you just search failed smog test you'll prolly find something.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
