Old 10-24-2009, 08:54 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Factory exhaust brackets
Someone was looking for these the other day so i figured id post them up . The small on goes under the cab on the driverside inside the frame and the big one goes on the on the drivers side behind the rear tire on the outside of the frame . I also have the one that goes above the axle and bolts to the crossmember . All three factory brackets shipped in usps priority flat rate box to the lower 48 for $20 .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
