![]() Join Date: Jun 2007
Timing issue ?
I Picked up a 67 C10 4x4 to use for a yard/Plow truck. It has set since spring without running, but I got it going pretty easy.
292, B model Carburetor. It was running rough so I set about to pull plugs, cap etc. Got everything cleaned or replaced as required and still runs rough. Starts pretty quick, just runs rough. Each plug had an identical "burn pattern" so I know each cylinder is more or less on equal ground. Have not done a compression test yet. I can pull each plug wire while it is running for each cylinder and make it sputter more or less the same, so I know there is nothing catastrophic inside the top end. It idles a little rough, balks and spits when you step on it, like the timing was off, if I hold a high idle (about 1500 RPM or so) it run OK but you can hear a cylinder or two dropping in an out. I chalked up the timing marks and threw a timing light on it, and could not find the timing mark, no matter how I adjusted the timing. Then I went around the motor looking for the mark with the timing light and found it at about 10 o'clock on the wrong side of the Harmonic Balancer. (Yes I was clipped to the No 1 Cyl.) When I dialed in the distributor cap so it ran as good as I could get it by ear the No.1 plug on the distributor is not at the front of the Distributor where it should be but back where No.4 is supossed to be, No.5 is in front. So sumpin' is outa' whack by 'bout 60 degrees. Any thoughts? Did it jump a timing gear?
DIY body and paint work is cheap, making it look good... priceless -------------------------------------------- My Toys; ’26 Ford Model T ‘72 Triumph Spitfire 1500 '09 "The Briggs Flyer" Gettin' High. |
70 Chevrolet=Obsession
Re: Timing issue ?
Sounds to me like the outer ring on your crank pulley might have slipped.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
#3 | |
Re: Timing issue ? Solved ?
![]() I pulled the plugs did a compression test while they were out, 125 to 145 all cylinders. So I know there is nothing wrong inside to contribute to the rough running. I ran No. 1 up to TDC and just put a new mark on the crank pulley. I have not run into a crank pulley slipping before, the rubber must be oiled up. I think for now I will put it back together, set the dwell, points and timing to the new mark, check for Vacuum Leaks and pull the Carb to rebuild and see if that will smooth out the motor. Question, it is a yard truck so should I bother to repair/replace the crank pulley? Could it actually come off? Weiging in at a few lbs I would not want it spinning around under the hood free at 2000 RPM's.
#4 | |
Re: Timing issue ?
It's the outer weighted ring that slips on the inner hub. It can't really slip off (as in flying loose) because the belt pulley holds it in place.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#5 | ||
Re: Timing issue ?
"Jumping" the timing gears is virtually impossible. They are direct gear driven, no chain to jump. It is possible to break some teeth...but that would be a catastrophic thing. You need to confirm the timing mark at TDC.
#6 | |
Re: Timing issue ?
To confirm TDC, Run Number one Cylinder Piston up to TDC on the compression stroke and see where the timing mark lies? Would it be possible for someone in the past to have removed the Harmonic Balancer and put it back on several degrees off?
I really hate wet sanding!
![]() Join Date: Dec 2008
Re: Timing issue ?
I would think it could slide to the reargetting into the front of the motor. Most like if that happened you could get it shut down before it damaged too much. Pretty sure you would here a lot of noise when/if it happens....reminding you to turn off the key.
