10-25-2009, 11:27 AM | #1 |
Fuel Lines
I have a 72 burb that needs fuel and brake lines front to back. I wanted to go the prebent route and have found the brake lines but not the fuel lines. Does anyone know if they are the same as the longbed pickup? Or a supplier that has them? Thanks allot
Bill |
10-25-2009, 04:26 PM | #2 |
Grandpa in the rustmobile...
Re: Fuel Lines
I would guess the burb lines and longbed lines would be the same..but im not 100% sure, i THINK ive read someone say that though.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-25-2009, 04:33 PM | #3 |
I really hate wet sanding!
Re: Fuel Lines
I would think they would be different....the truck tank is behind the seat while the burb is between the frame rails behind the axle! I would think the truck lines would be several feet shy of reaching. However, the truck lines go to rubber just under the cab, I guess you could use this part and then add enough hard line to it to reach the rear mounted tank.
10-25-2009, 04:38 PM | #4 |
Re: Fuel Lines
ahh see, glad i didnt tell him 'GO ORDER EM, THEY'LL WORK'
thanks for clearing that up^
10-25-2009, 06:33 PM | #5 |
its all about the +6 inches
Re: Fuel Lines
I just replaced all the fuel lines front to back on my burb a few weeks afo. If you were to get the lines for a pickup, then make the ones for the rear half, it would be very easy. The only part in my work that close to dificult was the front portion... from the back of the engine to the pump.
10-28-2009, 10:59 PM | #6 |
Re: Fuel Lines
where do you find the brake lines, I also need new brake lines, front to back?
thanks..
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
10-29-2009, 08:48 AM | #7 |
Re: Fuel Lines
LMC - they are their individuall - not listed as a set.
10-29-2009, 09:07 AM | #8 |
Re: Fuel Lines
prebent ones- any truck restoration vendor
straight unbent ones- any parts store |
