Old 10-25-2009, 01:09 PM   #1
psychobilly451
part interchange on front drum brake hose
my parts store doesnt have a listing for the passenger side front drum brake hose for my 1967 K20 (with manual drums)
they seem to think 60-66 part might interchange. anyone know?
otherwise I will just take the hose in to match it up.
1967 K20 Stepside Longbed 250-6 sm420
psychobilly451 is offline   Reply With Quote
Old 10-25-2009, 01:58 PM   #2
'68 C-20
'68 C-20's Avatar
Re: part interchange on front drum brake hose
Part No. for Bendix Hydraulic Brake Hose 88344
Centric Part number: CE150.68011
AC Delco 18J15, can also use ACD18J15
Supposed to fit either side?
DIY body and paint work is cheap, making it look good... priceless
My Toys;
’26 Ford Model T
‘72 Triumph Spitfire 1500
'09 "The Briggs Flyer" Gettin' High.
'68 C-20 is offline   Reply With Quote
Old 10-25-2009, 02:13 PM   #3
mbgmike
You beat me to it.
numbers are for K20 but not for a HD K20
we charge $33.00 for the Centric
supposed to fit 1961-67 certain models both same part. To be safe take it in and see or get a shop to make one
are you sure the 18J15 is the front? it comes up the rear on our parts system
mbgmike is offline   Reply With Quote
Old 10-25-2009, 02:38 PM   #4
'68 C-20
'68 C-20's Avatar
I just Googled the 18J15 and I see it listed as a Front hose on a site and rear hose on others.
You are probably right, it is probably rear. But the first two numbers should give him a cross reference anyway.
Thanks for backing me up ! Bad info is worse than no info.
My Toys;
’26 Ford Model T
Old 10-25-2009, 03:10 PM   #5
mbgmike
No problem We use Nexpart here at the store but errors can happen on any system Damn machines
Old 10-25-2009, 09:17 PM   #6
eseaton
eseaton's Avatar
The part number for autozone is 88344, that is what I came up with while I was at work.
67 GMC SW 383 stroker/TH350 w/ 4.56 gears - under construction
04 GMC 1/2ton daily
07 GMC Acadia wifes daily
eseaton is offline   Reply With Quote
Old 10-26-2009, 09:16 AM   #7
'68 C-20
'68 C-20's Avatar
Yeah, they carry the Bendix part, They frequently use manufactures part numbers as their own numbers. If you go online to Autozone's Website, The very best online parts look-up there is for the non-dealer (IMHO) you can usually take their part number and google it, that will give you the Manufactures name and number so you can shop it. They will often give you the manufactures name right at their Website as well. Great resource they are.
My Toys;
’26 Ford Model T
