10-25-2009, 02:54 PM | #1 |
I built it
pulling a engine in a lifted truck
will a 2 ton shop crane lift high enough to get a 454 out of a truck with a 4in lift and 35's? or other ways to get it out? i gotta pull it this week
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
10-25-2009, 03:42 PM | #2 | |
Re: pulling a engine in a lifted truck
With a lifted truck it may just be easier to pull the front clip off first. It's not so much that it is too high to pull the engine out, it's just a PITA to do all of the climbing necessary to unhook it.....and then again to replace it.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-25-2009, 05:24 PM | #3 |
At least put some smaller tires on it!
10-25-2009, 05:28 PM | #4 |
I built it
yea i was gonna get some smaller tires. and i dont mind climbing in and out im only 17 so that aint a problem i was just wondering if the crane is big enough haha
10-25-2009, 06:34 PM | #5 |
we used a regular 2 ton lift to pull the motor in my 68 once. it had 6 inches of lift and 33's at the time. but the motor just barley cleared. like the oil drain plug on the oil pan just touched the rad support coming out. that was a sbc tho. so idk if the bb will make a difference to the jack ( i assume it would) i would just throw some junk rims on the front or somethin and drop it way down just to be safe. cuz we wrestled the thing up to get it outta my truck and we werent sure it was gonna clear and that was just like a nightmare with the engine hoisted that high and all
10-25-2009, 10:36 PM | #6 |
Currently Blazerless
It really depends on the shop crane, some of the professional cranes may do it but if your talking about the ones sold at Harbor Freight and some other discount outlets then I agree with Longhair on pulling the front wrap. You would have to have your boom at full extension and probably raised to the highest point...and along with the weight of a big block I wouldnt want to be around if it were to start to fold up on you.
With the front wrap off it also gives you a lot better access to clean and detail that engine compartment while the motor is out.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
10-25-2009, 10:39 PM | #7 |
since you will have to drain and pull the rad any how.... pull the front clip off,
just pull the wiring harness off at the block, and its 8-10 bolts and you wont have to worry about trashing anything. |
10-25-2009, 11:19 PM | #8 |
I built it
i went out a little bit ago and was taking some rough measurements it and im prety sure itll clear. my bro has a really good shop crane, and we extended it out and up and it should clear. ive done a engine swap in this rig before but not since the lift... but like i said i measured it out and it "should" fit. but the crane is at its limit if i keep the 35's on, so im gonna get some junkyard wheels and tires for a while.
10-26-2009, 02:39 AM | #9 |
better take the fan and any shiny pullies off, they will be pushed into the boom arm when you stand it up that steep.
10-26-2009, 07:42 AM | #10 |
I drop my trucks onto the rotors.
10-26-2009, 10:56 AM | #11 |
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
10-26-2009, 11:35 AM | #12 | |
I built it
i was thinkin bout' doin that, but i dont really want to screw up my fairly new brakes... with my luck it would
10-26-2009, 05:45 PM | #13 |
I pulled my front clip off. Not that big of deal and makes it so much easier.
10-26-2009, 07:07 PM | #14 |
my buddie richie says pull the clip
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
10-26-2009, 07:34 PM | #15 | |
Cut back on Richie's caffiene intake......LOL
10-26-2009, 08:44 PM | #16 |
Windy Corner of a Dirty Street
Pulling the front clip is a lot of unnecessary work if you ask me. Pull the front tires and rest the frame on jack stands just behind the front shackles to the point the rotors are just a smidget off the ground. I have pulled probably a hundred engines in my life on my toys and working on other people junk at my dad’s shop on various trucks and never once pulled off a front clip.
Infusing 454HO with jack stands on the frame. 4” lift springs A few years later. Injected 454HO with jack stands on the frame. 6” lift springs 8.1L install. Jack stands on the frame Plenty of room 1988 Suburban with 6” lift getting a new 6.5L. Yep, jack stands on the frame and a jack under the juice box.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
10-26-2009, 09:55 PM | #17 |
Got big-block?
No front clip makes it eeeeeeeeeeeeeezzzzzzzzzzz!
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
10-27-2009, 02:07 AM | #18 |
I built it
i just today found i dont need to pull the engine!!! im happy for now. i thought the rings were goin bad but i found the ignition system had gone out at least its a easy fix.
thanks all for the replys!!
10-27-2009, 08:54 AM | #19 |
Well...that`s easier,huh?
Just for anyone else in the future.You can do what Dirty Larry does or what I do is put the rotors on a piece of wood,doesn`t hurt a thing.It`s just nice to bring it down to your size and not work with the hoist up as high.I see alot of guys pulling clips these days.I`m sure that`s not too hard,but I`ve never done that.I definitely put and engine in before installing a clip if it`s off.I`m usually working on a truck where "yet to be disturbed" is the rule and I like keeping it that way as long as possible.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-28-2009 at 10:14 AM. |
10-27-2009, 01:50 PM | #20 |
I built it
yea, i really didnt want to pull the clip yet. mostly because im not very good at aligning body panels but as soon as this truck starts the actuall restoration its all getin pulled apart and built how i want it. currently is undergoing a semi-daily-driven restoration as i call it haha. but thanks again for all ya'lls help
10-27-2009, 05:17 PM | #21 |
Dude bro, If your need to come down a few inches, like to pull the engine of what ever, no need to pull the wheels, just let the air out of the tires. With 35s should be able to get about 8 or 9 inches.
10-28-2009, 09:12 AM | #22 |
can actually DROP the truck on the rotors from full ride height and probably do no harm.
ign=blue smoke/bad compression?
RN U OVR |
10-28-2009, 09:46 AM | #23 | |
Talking about pulling the engine, when and if you do, doing any of the mentioned above, they will all work...if you set it on the rotors with or without wood, make sure that when your done and putting the rims on make sure the rotor turns free with no grinding, many times the rotor backing plate will get slightly bent and will rub the rotor, it may not be much but enough after a bit of driving it will score the rotor enough to have to replace it. I have seen this happen many times, guys would pull motors or whatever and then end up with brake problems or a noise they couldn't diagnose and bring it to my shop, this would be the prob many times. We usually put on just a set of steel rims and set it on the floor, that way if you do have to roll it, it still will, with it on stands, your stuck until you remove em, and that can be a real PITA and also dangerous. I have worked on many of a lifted truck, there are loads of em here, all work trucks, not just TQs. Dave
Dave & Marilyn in Rio Rancho NM....1967 Chevrolet C-10 long step side.....250 3 spd. ..... 1968 Chevrolet C-10 long step side.....325 hp 350 4spd.....3" Exhaust....etc. 1965 Chevrolet Suburban K-10....292 4spd....cam....etc. Bow Tie Baby |
10-28-2009, 10:16 AM | #24 |
I call it a rolling restoration.
10-28-2009, 07:54 PM | #25 |
Kid's Mechanic
Poor boys have poor ways. LOL
