Rims
Will these rims fit on my 71 GMC 5 lug disc brake truck?
They are off a 88-98 GMC truck? Thanks
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
Re: Rims
Yes, but if I remember correctly they will sit about an inch too far into the wheel well. They look a little funny because of that.
There may also be an issue with the hub size, but I can't remember for sure on that one.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Never Ending Projects
Re: Rims
Yes they will fit and I belive '88-'98 have about the same offset as the prior years. I know I put a set of aftermarket 15x7 wheels that were on a '71 truck onto my '98 truck and they fit perfect and just like they did on the '71.
I also put my '98 stock wheels on my '68 after the 5 lug conversion and had no issues with the hub size. My .02 worth.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: Rims
the offset may be a little pronounced. you could go with a set of 1" adapter/spacers if you want.
btw, I've always loved those SS/Sport rims!!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Re: Rims
Anyone have some pictures of these rims on a 67-72 long box?
