Old 10-25-2009, 05:39 PM   #1
Daniellane
crew cab 4wd
what do i need to do to convert my 82 2wd dually to 4wd drive single wheel. i have the axles. just wanting to know bout the frame and such
Daniellane is offline   Reply With Quote
Old 10-25-2009, 07:04 PM   #2
sailed2japan
Jonny
sailed2japan's Avatar
Re: crew cab 4wd
diy4x4 has a kit for this. look in the offroad section and you'll find a world of info.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 10-25-2009, 09:30 PM   #3
Daniellane
Re: crew cab 4wd
diy4x4?
Old 10-25-2009, 09:34 PM   #4
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: crew cab 4wd
here my 4x4 dually. im wanting to take it to just 3/4 tons rears
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 10-25-2009, 09:46 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: crew cab 4wd
Originally Posted by Daniellane View Post
diy4x4?
http://diy4x.com
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-25-2009, 10:40 PM   #6
sailed2japan
Jonny
Re: crew cab 4wd
oops, sorry, put an extra 4 in there on ya.
-AEC Hundley USNR
Old 10-25-2009, 10:42 PM   #7
sailed2japan
Jonny
Re: crew cab 4wd
well, you've already got the bed off, so you're half way there. Just need some axles, you could also just swap the hub assembly for the front axle.
-AEC Hundley USNR
Old 10-25-2009, 10:54 PM   #8
Daniellane
Re: crew cab 4wd
looking to go to 2wd? and i didnt see the kit. got a link?
Old 10-26-2009, 04:49 PM   #9
sailed2japan
Jonny
Re: crew cab 4wd
You're looking to turn your 2wd into a 4x4, right? it should be the B-52's that you can use to swap to 4x4. Shoot them a message. I've never delt with them personally, but I've heard they are more than helpful.
-AEC Hundley USNR
Old 10-26-2009, 05:51 PM   #10
Daniellane
Re: crew cab 4wd
yeah. is that all i need? if you could just help me with a parts list
Old 10-26-2009, 09:12 PM   #11
sailed2japan
Jonny
Re: crew cab 4wd
The kit that diy makes will work with 52" rear springs and give a 4" lift(from what I'm told) I would use that and get 4" rear blocks or springs (preferably) and you'll also need all the obvious stuff that a 4x4 is lacking; drive shafts, transfer case, etc. Also the pitman arm is different on a 4x4 so you'll have to change that.
Keep in mind I have never done this, but I have looked into it. You will probably come across some things that I haven't though of or seen since I haven't done it. Your best bet is to dig in the 4x4 section i know there are threads in there of guys doing exactly this. find one of them and ask them the particulars. They will be able to elimnate mor surprises than anyone else.
-AEC Hundley USNR
Old 10-26-2009, 11:35 PM   #12
Daniellane
Re: crew cab 4wd
yeah. pitman arm? and if i wanted to lift it 12 inches could i use 1/2 tons 4wd springs? cause i have a set
